Old Craftsman welder
BearCuda
Martinsburg,WV
When doing some cleaning in my dad's garage (he passed in 2009), I came across this old Craftsman stick welder hidden behind his table saw. I don't recall ever seeing this as a kid and I doubt he used it even once. It has a patent date of 1969 on it and a manufacture date of 71. Anyone else have one like this? It's very unique. Sorry, pics will take a few posts due to inability to resize from iPad quickly.
zkling
It's the rainbow welder.
It is a basic AC, transformer based stick welder. Not feature packed, but hard to kill.
May Pop
Lake in the hills Il.
I got mine which is exactly the same when I was 15 years old in 1973. Great machine!.
My mother went 1/2s on it for my birthday gift. Tons of great and poor welds as I grew up. Still have it in my garage as a back up for my MIG welder. It was about 150 bucks back then.Mine has not looked that nice in many years. Yours is in really nice shape.
Dewaynep
My Dad has that same welder. As has been said before, it is a good solid welder. My dad and I have welded everything from sheetmetal to 1/4" thick steel with it. It has never failed to work.
great white tj
Ocala Fl.
That is a Keeper, it looks like it has had little or no use. Even if you don't weld much it is still a keeper,they work great and as said in other post it is hard to kill.Get some rods, and fire it up and melt some steel.
BearCuda
Martinsburg,WV
There were old rods with it but they wouldn't be any good to use right? Why is it that you have to keep new ones in a sealed container?
LG63
Give them a try, I've found that 60XX rods aren't that sensitive to moisture.
chrisa7164
E. Taunton Ma
technically only Lo-Hy rods used for critical work have to be moisture free. I have 7018 rods that weren't stored in sealed tubes I've used for quick fixes that fired up fine. Not saying it's correct to do that,but it has been done. Also 6011 and 6010 need moisture in their flux coating to work right.
NUTTSGT
Northern Central Ohio
List it on Ebay for some ridiculous price since it's "ultra rare" and some poor sap would probably buy it. Unless you want to keep it for sentimental reasons.
bonacker
I've got one too. Got it in 1970, kept it covered when not in use, put wheels on it so I could move it around and it still works great. The only issue I've had is the nut on the handle/lock would loosen and the amp setting would change when striking an arc (go lower). LockTite finally cured that. Have welded millions (seems like it, haha) of feet and the machine still looks like new.
tcianci
Walpole, Ma
Well I guess it's not a very rare machine...I have one too!. It's the machine I learned on. My dad bought it in the early 70's and I still have it. I haven't used it since I got my MIG but it's a great machine. Certainly a step up from machines that only offer steps or taps by which to select the amperage. I have found that drying out obviously damp reds in an oven will help them, but most of the time I just clamped them in and burned away!
raddksn
south central upper peninsula michigan
You can weld rainbows with this thing? (LOL) All kidding aside I have not the same one but something close 230 amp I think. Have used it off and on for 30+ years, works good in the 85-110 amp range with the right rod. Get some 3/32 7018AC and make some sparks and have some fun.
tshetter
Central, FL
I have the same welder, built 04/1972:
13+-+1
My uncle used it to build a few bridges back in the day. Don't know if it was civil or commercial/residential, but that is what I was by my father.
IMO, its a good machine. I've used it to build a large reverse flow smoker, 12'x3' cooker with a 2'x3' firebox set on a double axle car trailer.
Was just using it the other night working on a smaller, more reasonably sized smoker, more on the range of 2'x3' cooker body.
I was able to pick up a Lincoln Pro Core 125 at Lowes for a riduculous price because they said it was missing parts...a $7 part they actually carry in-store.
Haven't gotten a hang of the mig yet, but I am working on it.
Back to the Craftsman...only issue on mine was that the amperage adjustment handle would slip down in power, especially if the electrode stuck. Just had to tighten down the nut/bolt and it works like a gem.
Of course, hang on to it, use it, and make a smoker for some ribs/pulled pork. :rocker:
