JoeFin
A 50' run of 10 awg will be fine
40 amps continuous on 10 awg would be 90 C (194 deg F) so I'm "guessing" 50 amps will be way under the ignition point of a wood framed structure.
From past experience the most likely failure points will be at your connections. So if you were to use a grounded 4 11/16 steel box with raised P ring in your wall you would be pretty safe.
That's what I am doing with my welding receptacles in the addition I am building now. That and I bought the 16" bracket arm to go behind the steel box for additional support. Changing plugs on the old box made it flex a lot in the wall and was getting a bit scary
