garage water heater
cparcell
hillsboro ohio
so i just bit the bullet and ordered a tankless water heater for garage. single point bosch rp9p. anyone have luck with these in there garage instead of a conventional unit.
Charles (in GA)
50 mi south of Atlanta
Why the RP9P?
Specification sheet shows it is a 277V only. Are you in a commercial building with 3 phase power?
The RP1P is the 240v version of the same heater, same specs.
Charles
C
cparcell
hillsboro ohio
Oh local guy ordered the wrong one, now to find a buck boost for cheap. Do I need to worry about it really as it will just be for the garage sink. Does it kill life span on them to not boost them
Charles (in GA)
The 240v model is designed to work on 220v and 208v. It is at 75% capacity on 208v. There are no electronics that are voltage sensitive so I think it would work about the same as the 240v model being run on 208v.
My problem is incoming water temp is no more than 50° and I want about 105° output, so the 9.5kw model is not enough. There is a 12kw that at 1.5 gpm (it is a 2.0 gpm max) will give me the 55° rise in temp. Found it on Amazon for $199 free ship.
I am currently using a Titan 2.5 gal tank type under counter unit, 1500 watt 120v. OK for hand washing, but filling a bucket with hot water is a problem.
Charles
C
cparcell
hillsboro ohio
im not the best with electrical understanding but if i get a 1kva buck booster that should raise it to around 263v in my simple understanding. i have seen some used units on ebay for 40-50 bucks. if i can get 100 degree water for my sink with out boosting i would be satisfied.
Plump
SE Wisconsin
Not a super technical item for help, nor do I know where you live but...
make sure to purge the water in winter if you get freezing temperatures. My buddies needed to be replaced after his first winter. Oops.
aardquark
Just a caution with tankless water heaters if you are thinking about
  1. Using a glycol-based system for freeze protection
  2. not keeping the system warm all winter
Upon careful reading of the operating conditions for a number of tankless systems, every one I looked at required a minimum pressure to operate. The assumption was that the system would always be hooked up to a domestic water supply and pressure reducer, for replenishing at about 7 psi. For me, this was a deal-breaker, because did not want any incoming water connection, to avoid the danger of it freezing when I let the garage go cold. Maybe there is some slick way to get around that, but I chose to defer using radiant heat until some time in the future when I am sure I want to use it ALL winter long.
C
cparcell
hillsboro ohio
I live in southern ohio and although we do have freezing conditions I'm going to regulate the shop above freezing all year. 45-50 degrees constant. My water supply there now has never frozen in the garage even after extended low teens. I have Well but my pressures are constant and regulated.
