Stuey
I've been trying to think up a benchtop testing jig I can use to compare the power output of cordless drills and maybe drivers as well.
It would have to be a benchtop system since I want to be able to hook up meters to record things like current draw and runtime.
I'm thinking I can set up a bearing-supported 3/8" shaft (drill rod?) that would be chucked into drills and onto which different weights can be clamped on, but I'm unsure as to how that can be easily done. I don't have the equipment to machine 2-piece cylindrical weights in a range of sizes.
(The different weights would be to simulate different loads.)
Maybe machinable bore locking collars would do the trick? http://www.mcmaster.com/#3374k12/=pv2ase Although I doubt my Craftsman 10" drill press would be up to the task of machining the holes.
If I use larger drill rod I can then use shaft couplers with short 3/8" and 1/2" rods that can be chucked into different sized drills, but this might affect the ability to do direct comparisons.
Alternatively, I'm thinking I could use pulleys and belting to create a jig where a drill slowly lifts certain weights from the floor via high tensile fishing line or steel wire. This wouldn't allow for runtime tests though.
Ideally the entire contraption could be placed within 80/20 frame with lockable door and polycarbonate shielding.
Any ideas for a different approach, or how to make this work? This is a down-the-road project so no urgency.
