Direct Lift Pro Park 9 Plus Installed
tdkkart
Eastern Iowa
Ordered my lift on Monday from http://www.derekweaver.com/rodders-garage/4-post-lifts/pro-park-9-plus-certified/, there were a couple items(transmission jack and oil drain bucket)on backorder so shipment was delayed a couple days with my permission so that my entire order could be shipped together. Arrived at the dock the following Monday.
Against my nature I hired a local installer, but in the end I'm glad I did. He picked up the lift at the shipping company on his trailer. These things are HEAVY. The shipping company's fork lift would not pick up the package, which was only the lift, the other items were packaged separately. They ended up partially disassembling the package to get it on the trailer. He said he'd never had this happen when picking up a 9000lb lift.
Lift, installer and helper arrived at 8am. This installer does service and installs on all brands of lifts and other auto service equipment in this area and has been in the business for a long time, however it is important to note that he does not do sales, you order from whoever you want, he picks up and installs. He is listed on Bendpak's website as a certified installer, and says he installs 3-4 lifts every week from all the major manufacturers, Bendpak, Rotary, Challenger, Direct etc, although he had never installed the PP9+. They arrived with all the equipment he needed to install the lift. Hoist on the truck, dollies and blocking to help move the ramps etc around, set up a table to lay out all their tools, laser levels etc. They came well prepared.
The install went very well and quickly. All the parts were there, and he noted that he had spent some time the night before looking over the manual since he had not installed this model before, so they were able to move right along. He did mention that the manual was much better than most.
4-1/2 hours later the lift was installed, leveled, tested and they were packed and ready to go.
So what do I think?? I think I'm thrilled. I've wanted a lift for a LONG time. Now I have one, and it's great. Did the first oil change on it this morning, and will be starting on a clutch change in my '96 F150 tomorrow.
What do I think of the PP9+??
Maybe it's better said by the reaction of the installer and his helper. Remember, he does not sell any lifts, only installs and services, so he sees them all and can rattle off the features he likes and doesn't like on all of them. He said you definitely get what you pay for when you buy a lift, and he said some of them are pretty scary.
From the time they started unloading the lift they were commenting about how they liked the various parts and comparing to other brands.
Some items they mentioned:
Columns are thicker/heavier/sturdier than most, and cables are inside the columns rather than outside.
Front and rear crossbeams are heavy "I" beams rather than square tube that most are.
Adjustable lock ladders, which he noted as very important in his opinion. These allow the lift to be leveled while it's on the locks/stops as well as when it's on the cables. This allows you set the vehicle down level on the safety stops rather than hanging on the cables while working. Non-adjustable stops on a sloped floor are a real issue.
Good quality hydraulic unit. I forget the name on it, but he said they have alot less problems with these than others.
Safety lock linkages on the front and rear cross members are all concealed under covers rather than out in the open where they often get damaged.
The lock actuator rod on this one is one piece while others are 2 or more pieces with threaded couplers joining the pieces. The threaded connections often come loose keeping you from unlocking the locks.
Heavier cables than some. He noted that while he rarely sees broken or damaged cables, heavier cables do not need as many adjustments as they stretch less than the smaller ones, which is especially a problem on 4 post lifts since all the cables are different lengths and all stretch differently.
Something was said about the cables/cylinder and keeping them from twisting, but I didn't catch it all and keeping forgetting to look.
Sliding blocks in the columns larger and better material than he sees in alot of lifts. Said he sees alot of problems with worn blocks on some lifts.
Numerous times he mentioned that he thought the PP9 was a very good value for the money compared to others.
So, I feel pretty good about my purchase, and have no doubts I made a good choice.
I'm also glad I hired the installer. Could I have done it myself?? Yes, most definitely, I would rate the difficulty of the assembly at about a a 5 for and experienced garage dweller, and if you have plenty of able bodied friends to do the heavy work there's no reason you can't do this yourself. But sitting back and watching someone do it was kinda nice for a change.
First oil change:
For the people who doubted Direct Lift's were certified:
Ross/Kzoo
Richland Mi.
I like it!
BTW Thanks for the narrative on the install and the installers opinions.
stea
Utah
What did the installer charge you??? Plan to get a lift within the next 6 months and have been debating on spending a week doing it myself or paying someone to do it in half a day.
sunshine1639
Congratulations on your lift.
Bought the same lift from the same company last year.
My wife and I installed it in about a day and a half taking our time.
Know you will enjoy your lift as much as I have enjoyed ours.
Gets used several times a week, sometimes more.
Wish it was inside but all we had was a large tall carport.
The carport is big enough most of it never gets wet and it is usually kept at the highest stop which helps also.
Have FUN and be safe...Sonny
T
tdkkart
Eastern Iowa
Nice !!!
It's bolted to the floor ? It came equipped with casters, correct ? Why didn't you elect to use them ?
By Transmission jack, do you mean the "PRO-JACK" https://www.derekweaver.com/rodders-garage/4-post-accessories/pro-jack/
Did not bolt it down, just sitting there.
The castors are not permanently mounted, they are like these: http://www.derekweaver.com/rodders-garage/4-post-accessories/caster-kit/
(The set that comes with the PP9+ has poly coated wheels rather than steel)
All 4 post lifts that I know of use this or a similar type of castor kit for moving the lift if needed. None are permanently mounted that I know of.
This is how most of them work:
I bought the Pro jack, but I also bought a seperate transmission jack for use under the lift: http://www.derekweaver.com/rodders-...jack-stands/w-1100-2-stage-transmission-jack/
T
tdkkart
Eastern Iowa
His charge for the whole job was $425, which included picking up at the freight depot and delivering to me. The only other install cost for me was the hydraulic oil. It wasn't cheap, but for 2 guys for 4-1/2hrs isn't cheap anywhere. It would have taken me some time to do myself. I thought it was a fair price.
8587GN
I just bought the PP8. Myself and 2 friends will be putting it together this Sat. I,and another friend bought two of them this past weekend, he put his together in about 4 hours, and will be helping this weekend . I cant wait for some garage floor space back
1965gp
I bought my lifts from the same guys and used the same installer this November. Service was awesome- in 3 hours they had both lifts installed and ready to go. Cost me a little more because I live in Houston and he had about 200 miles each way.
Like you- I am very happy with the quality of the lifts.
T
tdkkart
Eastern Iowa
One thing that I'm already glad I did was to get the extended height. I don't even really have plans to stack vehicles, and I can't use all of the height with most of my vehicles, but with the lift empty and all the way up I have 81or 82", nearly 7ft, of clearance to work under it with nothing in the way except the 4 posts. Plenty of floor space for doing whatever.
T
tdkkart
Eastern Iowa
This morning I cried BIG tears when I paid the credit card bill for the lift, but then I went out to the shop and pulled the transmission and clutch out of my F150 in just over 2hrs, never once getting down on the floor. It was WELL worth the money. In a couple months I will have completley forgotten what it cost.
Red89gt
Albany, OH
Install money well spent.
Wish I could find installers like yours in the Chicago area.
I do not have time or resources to install myself.
It's ok with me because if I had time to install it would mean I wasn't working and wouldn't have the money. I have been eyeballing a pro park 8+. My daily is in the driveway and I haven't been amused now that bad weather is here.
T
tdkkart
Eastern Iowa
So I read a thread the other day that all a lift does is lets you get under there and find more stuff to fix.......
So, I get going on the clutch replacement on my '96 F150 that pushed me into finally buying this lift now instead of later. Wow, easy-peezy working on the lift is AWESOME and the clutch swap went off without a single hitch. Bought a new tall trans jack with the lift that works perfectly, I cheated and checked U-tube for info on the clutch line and bleeding situation so that went off just as should have without aggravation, made my self a pressure-fed oil bottle to put the oil back in the trans, no runs, no drips.
Whole job went great.
While removing the drive shaft I did notice that the right rear brake backing plate was a touch damp. Hmmm??? Better check into that later, probably the wheel cylinder seeping a bit. Otherwise the rest of the underside of the 18 year-old 150,000mi truck doesn't look too bad, exhaust is getting tired, and some random rusty stuff here and there, but overall looks OK.
Finish up the job, crawl in the cab to fire it up and check the clutch, step on the brake pedal and it goes flat to the floor?!?! WTF?? Did it pop that wheel cylinder??
Jump out, look under the back and nothing looks different?? Check some more and find a puddle under the LF wheel and brake fluid dripping??
Look some more to find it blew out a steel line right at the front brake hose.
Jeez, looks like I get to spend more time working on the lift......
[/URL][/IMG]
8587GN
We assembled my PP 8 yesterday afternoon in about 4-5 hours. We had three guys, but called my neighbor for a fourth to help get the ramps off the trailer. It went together without any issues, and I rolled it into my car side of my shop today.
T
tdkkart
Eastern Iowa
What are your ceiling heights?
My ceiling is 11' 5", however it's not really a limiting factor for me as I'm a short fat *******(not really, I'm 5' 9") so with the truck all the way to the ceiling it's really too high to work comfortably. I just did a clutch on the truck, did most of the work one notch or 6" down from the ceiling. Also, when doing work on wheels etc really needs to be down further than that.
As I said earlier, I made sure I bought the extra height model, not so much for the vehicle height, but so I could raise the lift all the way, 81 or 82" and work under it when its empty.
Ak47si
I think $425 to pick it up, deliver to your house, and have it set up in less than half a day was money well spent.
Those are awesome prices for doing all the above. I am looking for an installer in the northern Jersey area, the installer i got was from bendpak webnsite installer listing serice...the lowest quote I got was $750, and the highest was $1000.
I am willing to pay up to 500 if anyone in this forum who live in northern jersey willing to pick up the lift from Conway and installed it at my house.
Anyone?
Alan
duckfatrules
greensboro, nc
question,
why did you buy the 8,000 lb model verses the 9,000 lb model?
I am getting ready to buy one or the other and need some advice.
$2,200 vs $2,900 plus tax
I can drive to Thomasville NC to pick up either model, is the 9K model worth $700 more?
I am not rich, but I would rather pay the extra $700 now than regret it later.
I am not a mechanic, I screw up more stuff than I fix, but I do like to have mechanics come to my shop to work on my cars.
I own a 1964 and a 1969 vett which weigh at the most, 3,000 lb each.
mainly I want the lift for storage to open up more room in my garage, to store other cars.
the lift may go up and down 15 times a year? However, I don't know what I will do when I retire in several years.
one negative I have noticed is that my garage door is only 8 ft tall, 96 inches and the 9k model is 97 inches tall, but with taller posts, i get to raise the car higher for walking under. Do these two issues cancel each other out?
