e-tek
Saskatoon, SK
I LOVE THIS THREAD!!!
For all of you who post here and wish someone would comment on how awesome what you did was, here it is: AWESOME!!! ;)
...and I mean it! From the 64 T-bird (pulling stg wheel was smart:rocker:), to the lift on the truck (no jack-:dunno:), the stop-action vid (great metal-work, bad dancing ;)) and then the rubber molds (what'd you use for rubber:headscrat)......like I said, awesome.
jmlcolorado
Elbert County, CO
Made a mold and poured Urethane for an unobtainable clutch rod boot for a 1969 full size Chevrolet. Found a NOS boot (finally) and used that to make the mold.
dla
I'm interested in your process! That's AWESOME!
What did you make the mold out of? And how about some detail on the urethane?
You could start a whole new thread of awesomeness on this topic! :bowdown:
CudaChick1968
Member Emeritus
Northwest Tennessee (38230)
The shop's new Introduction Movie is almost ready to debut to the world! :D The original's not that old yet but YouTube killed its soundtrack; ever since, it's been ten lonnnnng boring minutes of endless Powder **** and a redo has been under construction in my head for months now. This new one's gonna be stellar! Kinda sad to realize I've spent like 30 hours putting together less than seven and a half minutes of movie ... I have a much bigger appreciation for those Hollywood types now though.
Of course when it's done you'll all be the first to know. :bowdown:
The Boss
Connecticut
Put the new rubber deflector on the top of my SnowDogg plow. Should have done it this summer. Sold a fiberglass GTO hood too.
kellymc
Installed a 3 axis DRO from DROPROS on my millport, now to tackle the lathe today
Jimmy_B
I dug out my last Estes model rocket that I had as a kid. I started this in the mid 70s and have drug it with me through life for some reason. I pulled it out today and think I'll finish it. It appears I still have all of the components.
I found an unopened kit on Ebay for $175. That's a little more than I'd pay for it.
Manganos
Virginia
Finally got my MAXAIR line run in the garage and mounted my air reel on the post in the ceiling. I like it.
dladcock
North Carolina
Awesome job.
Mike.
I'm pleased and proud that you guys liked the Urethane parts. If you think a thread about the process would be interesting, I'll give it a shot.
dla
toolman1967
Benton Illinois
My son and his friends came over to help me get the motor and transmission in the Custom Harley we are building. Nice to see the motor in it since we made all the modifications to the frame and running gear.
I know, I know, I need a better garage camera!!!
Tim the Toolman
e-tek
Saskatoon, SK
I spent an hour straightening. re-finishing and polishing one of the TL bezels on the 40 Ford.
GTA Matt
Zebulon, NC
I set out to make a tool to turn the carrier bearing adjusters on a ford 9" that I could put a torque wrench on. While looking for a 1/4" thick piece of steel scrap to thread 2 studs into, I ran across my holding tool for Toyota balancers. Perfect fit! Two bolts welded to a piece of exhaust hanger, shot it with some red so it doesn't get mistaken for scrap and it works like a champ.
Manganos
Virginia
Pics or it didn't happen!! :)
OK. I only ran one main line for now until I figure out where else I need air. It is WAY overkill for my application since I just have a 2 car garage but I'd hate to do it over. If I want to add a line I'll cut it and install the "T" and come out with more lines. VERY easy to install.
rmmiller
Kennewick, WA
I pulled the engine out of my Maverick as well as some additional clean up. It's been a long haul getting the garage organized and I'm not near finished.
rharman
SoCal
I used to build those probably in the late 60's. In those days, you had to get a permit from the local Fire Dept in order to buy the engines.
Was at a Michael's store today and saw someone buying one of the kits and engines. Looks like they come ready-to-fly now. Pretty boring and how can kids learn to build anything? :dunno:
$175???? Maybe in someone's dreams.
Guster
Auckland, New Zealand
Re: What did you do in your garage today?
Painted the base and main machine casting as well as the ram, doors and flywheel cover on the Alba 1A during breaks from doing gardening and landscaping. First time using a mini roller for applying paint after cutting in with a brush. I like it! Started assembly and fixing bits as I go during breaks from doing more gardening the following day. Starting to resemble a shaper again.
Finished the day degreasing and polishing the remaining bits. Should be able to order the drive belt and start building a replacement compound mount and a new clapper box. Pretty effective weekend. At this rate I might even get the band-saw reconditioned before Christmas.
The shaper is running but still need to finish machining the clapper. Scored a Tom Senior M1 mill today. Needs a thorough clean and paint. Disassembled it to get it off the trailer in parts. Amazingly heavy and compact little machine. Hope it has a few more decades in it. Will all have to wait till next year now. Two weeks of camping, kitesurfing and quality family time ahead. :rocker:
Lippyp
Shropshire, UK
Drank some beer, listened to some music and PSA. (Put "stuff" away) after just lobbing tools etc in through the door when cleaning up for christmas and finally finishing a refurb on my study. I also finally wound my longest extension cord onto the old wooden cable drum the underground cable I used to power up the garage came on so its finally no longed a tangle up mess after about 15 years like it!
Responder
Saskatoon, SK
Read the code on the scanner on my daughter's Equinox, 7EA and 7E8. Did some research and it looks like an "intermittent misfire", sounds like it is usually plugs. Hope it is that simple
Jimmy_B
How OLD are you now and how old is the rocket?! Is it still going to fly straight? LOL!!
The rocket is from '75-'77. Not exactly sure. I'm 51 now. Time will tell how straight it flies.
We never needed permits that I'm aware of. This model was revised in the late 70s with plastic molded parts for easier assembly. That won't teach the kiddos much.
$175 for an original unopened complete kit. A collectors website I found lists what these have been selling for and that's about right. Collectors are goofy. :lol_hitti
vartz04
LaSalle County IL
Installed a new pressure switch on my Montgomery ward compressor. Also added another 220 outlet so my heater and compressor don't share (pain to plug/unplug jn the winter)
Sent from my SPH-L710 using Tapatalk
CudaChick1968
Member Emeritus
I finally got the shop's new Introduction Movie done!!!!!!!!!
Oh thank God, whewwwww. After this, I have a lot more respect for those Hollywood movie producer types now LOL! :D
As always, comments are welcome and appreciated! I'd love to hear what you guys think -- your opinions matter a lot.
SliderXTM
Germany
Made some "finetuning" on my newly installed Nexus 7 tablet and disassembled the rear wheel brakes...
bhays
Southern Indiana
Worked on my Corvette project. Just about to pull the motor. But the intake has to come off to clear the lift chains and you can't get to those bolts until you pull the runners which won't come off until the valve covers are off so, I called it a day and plan to reattack this evening. View attachment 303142
I need to get it done and get the body back out of the driveway before the family shows up for Christmas and it's a topic of discussion. Lmao.
jose's garage
LI, NY
bored, built a bracket for my air tools out of some stuff i have laying around. i just cut straight up. works awesome.
b-body-bob
Almost Heaven
^ I've used that stuff before to hang several air cleaners on the wall. Thanks for a new way to use it :thumbup:
It took all weekend but I disassembled and removed this
Then stood this up and got it working
carterbeauford
NW PA
disassembled Vidmar cabinet and hauled to powdercoater
installed Craftsman pro vise on bench
jointed 3" cherry slab and walnut legs for coffee table project
ripped out about a ton of 2x10" oak flooring I got for free from an abandoned business and hauled to sawmill to be resawn and turned into flooring for my new shop
I can hardly walk :lol:
GCncsuHD
Salisbury, NC
You forgot "all while jamming out to Rush." :pimpflash
