Should I buy a small vice?
GoodEnough
I got a thread chaser kit, and realize people tend to use them with a vice.
I have a small detached garage, and don't really have a workbench. I have nowhere to really secure a vice. Can I keep one on the floor? Maybe secure it with my foot or something? I have seen someone say they bolted one to their toolbox, which could be an option.
But, can someone suggest a cheap HF vice that might be worth considering? I might never even use it, as I've gotten this far without one.
http://www.harborfreight.com/catalogsearch/result/index/?dir=asc&limit=60&order=Sort+Price,t&q=vice
Vvmvbb
CT
How can you live without a workbench?
Get a bench then bolt a vice to that.
Bigplum
Cotswolds England
If the garage is really small , get a half shaft from a rear axle , drill a hole into the floor the same size as the spline and cement or epoxy the shaft in, then bolt a vice to the flange , it might ring a bit if you start beating on it but it'd be plenty strong enough .
1982fxr
Phoenix
pretty much any old American made vise (and many imports) you find on craigslist will be better than harbor freight. But if it's not gonna see heavy use, or even medium use, any of those $40-60 cheapies will do.
Can probably find some kind of a used bench on craigslist for free or very cheap. Lots of times people just want them gone...
tgb
Southeast Iowa
Everyone is giving you the business for no bench. I understand not having one, what I did was build one that is folding. I mounted it on the wall with a piano hinge and folding legs 30 seconds to setup and takedown, and small enough against the wall you can still open the car door when it is folded down.
F-Bobby
Boston Mass
I'm in the same boat. I dont have any place to keep a work bench set up. I was looking into collapsable ones for bolting a small vice to. The most i'm gonna be using the vice for is freeing up stuck brake caliper slides or maybe removing/installing Pulleys onto PS pumps and stuff of that sort.
devoncoolman
quakertown pa
Honestly even a small bench some 4x4's with a ply wood top is better then nothing cost u $20-$30 to build and get a cheapy vice from hf or sears there ya go. If your not going to beat the **** out of it. Any vice will do u. Youve gptten this far with out it so anything is an upgrade. You will wonder why you didnt build a bench and buy a vice years ago. Honestly surfing cl and local flea markets are your best bet to find a vice and maybe even a work bench.
scaron
ypsilanti, michigan
i lived for many years in rentals and never had a work bench (except when one came left behind with the property) because i didn't want to worry about trying to move it when the lease was up. it sucked, but what can you do... i was able to get pretty much everything done that i wanted to, only a bit dirtier, from grubbing around on the floor all the time, LOL. that said, now that i've got my first real house here, the first thing i did was construct a few benches and i'll concur, it makes things SO much easier (and cleaner). benches are easy and quick to build; even if you don't have much room, you can do 2'x4' for less than $50 in lumber and screws with maybe an hour of work.
460Rustang
Nawlins
pretty much any old american made vise (and many imports) you find on craigslist will be better than harbor freight. But if it's not gonna see heavy use, or even medium use, any of those $40-60 cheapies will do.
agreed,..................
Outlander
Quebec, Canada
My Dad had a vise bolted onto a thick piece of wood that he clamped into a Black and Decker Workmate. A used vise is also a fun project!
G
GoodEnough
I pretty much have just enough room to walk around the car, and about 2 feet in front of the car. There I have a 5 level shelf for my toolboxes, tires, spray cans, etc....and my floor jack, compressor, and a cinderblock. No real room for a workbench.
It's sort of like this, but picture a car parked in there.
Not much room
G
GoodEnough
Same here. I just do light basic automotive. I have never needed a vice, but got the idea when I wanted to put a die into a vice to screw a bolt through it. It's not worth making a whole thing over it, but if I had something like a barstool as a small platform, that took up little room, that might be all I need.
CNGsaves
KS and OK
The insanity just keeps getting worse for OP:
a) can't drive down to HD to buy a few bolts
b) never heard of Ace / True Value Hardware
c) lives in neverland that can't be told to GJers
d) asks how to buy first set of tools ever
e) critical of operation of ratcheting wreches but never has owned them
f) NOW asks Why anyone would need a Vise ??
. . . . Yes, the word is VISE . . . so likely OP isn't anywhere in North America !!
/ FUTILITY . . . . might be powder puff forum somewhere for this guy !! :lol_hitti
thebeekeeper1
Illinois
Not much room
Surely you have kitchen counters--bolt one on there. You'll be surprised how many uses you find for it. :rocker:
CNGsaves
KS and OK
Yeah, this is a Goosechase for sure. Someone can reverse image that "garage" he's shown as that for sure is NOT his . . . guaranteed !! :D
See his other threads on Helicoils and bright light is coming on!! 1st thread he wanted to buy bolts over internet, rather than in person. Now wants to learn about helicoils. But first, oooooh yeeeees, have to learn about a VISE !!! :eyecrazy:
Bottom line is he's buggered up some threads on something but won't tell anyone what it's for . . . . may not even be car related. :eyecrazy:
OP, hope you've got a neighbor or friend/family that can help you out. Phantom questions on GJ and tip toeing around your problem won't ever get it solved.
/futility
DieselSaves
Big Sky Country
I have seen vises bolted to a bit of receiver tube to be used on the trailer hitch of a vehicle. If you have a tow hitch on even a car, it could be used as needed. Store the vise til you need it, then put it in the hitch and use it.
G
GoodEnough
No hitch, but good idea.
A vise or vice (see American and British English spelling differences) is a mechanical screw apparatus used for holding or clamping a work piece to allow work to be performed on it
PCO6
Newmarket, Ontario
I'm not sure how any one can get much work done without a vise or a vice but just to clarify one thing ... In Canada the correct spelling is "vice".
Zeke
One thing about HF that I do believe is that their vises are crude.
But so are my vices.
Nick Danger
Albuquerque
Build a fold-up workbench on the wall. Buy a small clamp-on hobbyist vise an store it in your drawers. Even a small vise will make a lot of jobs easier.
CNGsaves
KS and OK
I only do light automotive maintenance.
It's not a real workshop.
Put up PICS of buggered up thread hole you're trying to fix.
What does this "magic bolt" go into??
Let's see PICS of this "part" you have that is needing bolt, helicoil, and now "vice" that you've never owned in your life !!! :bounce:
:needpics:
drivesitfar
I didn't see anyone mention an old wheel with a post welded to it with a plate on top to mount your new vise to. I am going to sell a couple because no longer need and I've seen several on Craigslist over the years. HF also sells a cheap version you can mount a vise or grinder to for about $30. that way you can set in a corner and pull out when you need to use it.
I do like the workbench that can fold up against the wall when you are not using it so you can pull your car inside the garage.
English or US made old vises would be first choice if you can find a deal on Craigs or estate/garage sales, but some of the Chinese ones seem to do fine for some.
uart
Australia
+1 on this.
Hi Goodenough. This in my opinion is definitely what you should do. You'll find a small foldable work bench like the BD workmate (or similar) to be really useful.
Without a permanent solid workbench you won't be able to make *full* use of any large or expensive vise anyway, so in this particular situation I'd say just grab a cheap 4" swivel base one like this: http://www.harborfreight.com/4-inch-swivel-vise-with-anvil-67035.html.
Jeez CNG, give Goodenough a break. Having him here on these forums makes me feel like less of a noob. :p
uart
Australia
Yeah, those all look ok. Take a look at a few "in person" if you can, get a feel of the weight and how solid it feels before buying.
What are those cranks for? Do they move the 2 planks of wood.
It makes it like a basic woodworking vise. You'd still want a little 4" machinist style vise though, for the stuff you want to do.
xSoFx
Honestly, get a workbench. Folding or solid. Nonetheless, harbor freight also sells a universal tool stand that you could put the vice on.
