Torque wrench for < 14nm
ilovevocs
Toledo, Ohio
As the title states I'm in the market for a torque wrench, looking like 1/4", in the torque range of 2 to 14 nm. I can live with 13.something nm but I'm torquing allot of assemblies in this range in my home shop. This is not a professional application but I'm not a believer in cheap ( read low quality) measuring instruments. From what I have seen I can get a descent unit in the $250 to $300 price range. I wouldn't mind spending less but I'm not prepared to spend much more unless their is exceptional value at a higher price point. Looking for opinions from those who have purchased and used products that align with these attributes. Thanks...
ishiboo
Oshkosh, WI
I'm a big fan of the GearWrench clickers, though the 1/4 starts at 30 inch-lbs which is a bit higher than 2nm. (~17)
The wrenches were formerly all Made in USA, I bought 2 from NTX and they were still USA stock.
sberry
Brethren, Michigan
What is a Lot of assemblies? There is no reason for a home brew guy to spend 300 on a wrench, the HF will work for 22$ for doing a head on a small engine, buy something else you really need with the change.
Steinmetz
Washington State
Exactly what do you want to do with it? "...torquing allot of assemblies..." isn't descriptive enough.
SMKS
USA, planet Earth
The GW torque wrenches are still made in the USA. I've never heard that they switched to imported torque wrenches. Where did you hear that?
Treeman
If high quality is important to the OP, then he should look at the major players: Precision Instruments, CDI/Snap On, Sturdevant, and maybe Proto.
At that low of torque, I too, would only consider a dial type or an electronic type that shows the progressing torque.
Back when I studied torque wrenches about 6 years ago, Precision Instruments was noted having the dial type being their forte (just internet opinions).
I
ilovevocs
Toledo, Ohio
Thank you to everyone for their comments. I will share more later; posting on my phone at the moment so it's difficult to respond to all.
HF is a no go and not part of my consideration. I own a HF torque wrench that sees some use from time to time but not for this application.
The gearwrench was my first consideration. I have been buying allot of gear wrench lately and am eased with the performance for the price point. Nice tools for the home shop
I'm leaning towards a dial type wrench, thus my price range indicated above. I don't want a clicker, would consider electronic. I have used electronic in the past but feel the dial would be more appropriate for such a low torque range, as stated above. At this juncture the proto is on the top of my list.
Was hoping for some feedback from owners of tools as mentioned above; snappy, ect.
shockwave
Marietta,ga
Look into some hazet stuff thru eBay they are really nice.
But that low of torque you might be better off with the screwdriver style torque wrenches
MadTinkerer
Agreed with the hazet comment. I picked up a 1/4 2.5-25 nm torque wrench that has been rock solid. I bought it off if Jens putzier who is a member here. After shipping and duty I think I paid right around $150 for it.
ihateminimumwage
They still are. Apex makes the GW, Matco and now Husky USA torque wrenches. Best bang for your buck (even with the low tooth count).
Charles (in GA)
50 mi south of Atlanta
For very low torques, I'd consider a beam type, or a torque screwdriver.
Sturtevant-Richmont beam type torque wrenches
Seekonk torque tools
Mountz torque tools.
