Harbor Freight Hose Reel $69.99
L
lakebilly
blind
KY
I bought one a few weeks ago and was disappointed. It's flimsy and, even after tweaking, didn't have enough tension to reel in the hose completely. I discovered this after having to notch the guide roller arm so it could rotate 45 degrees. It's already predrilled for the location but the arm would not clear a bolt head.
It's currently in the box waiting to be returned.
brimorga
Bay Area, Ca
I just mounted the 50 ft one on my ceiling a few days ago. So far, so good. I don't expect the hose to last forever but hopefully the reel will last a while.
chopt49
Pilot Hill, CA - USA
I have gone through 2 of these, they develop a leak at the entry point that swivels.
Going to go will higher quality one this time around.
ActAppalled
Lancaster, PA
I was going to buy one if those but I found a Jupiter Pneumatics (MSC House Brand) reel about the same size that I can get for cheaper with my company discount. We had one at work along with our Reelcrafts and there wasn't much of a difference in quality. Considering a comparable Reelcraft goes for about $300 and up I think I'll take a chance on it.
owenst7
Anchorage/Reno
I've had one on my ceiling for a couple years. I think it's one of the better products HF sells. It's pretty heavy steel and will whip the hose around if you let go. It's better quality than the rebranded Amflo ones I used to sell for around $150.
L
lakebilly
Good enough. I live in the town where Reelcraft is, Columbia City, IN. They make a great product and employ a lot of people.
I will pursue a Reelcraft with the hope I can get one through an employee.
Thanks for all of the feedback.
ActAppalled
Lancaster, PA
After the initial sticker shock wears off, you won't be disappointed.
70C-10
Mn
Is it possible to fix it using non HF parts ?
shannonw
Florida
i thought i read on some other site (i've never seen how it's put together) that there's some o rings in the swivel you can replace?
I'm thinking on picking one of these up and putting flexzilla, flexeel hose on there.
pipsters
USA
Yes they are #10 orings IIRC
I put a Goodyear air hose on mine, hose is much nicer than stock but its heavier so I had to tighten the spring a bit. A flexzilla would be a good choice.
