Guys,
Solve the puzzle, win a prize.
I just fired up a closed radiant heat system, with 50/50 antifreeze made for radiant systems. The in-floor Pex and all other associated fittings are leak free. When I first filled the system with oxygenated tap water, then drained out half the water and pumped anti-freeze, I used the fill/purge valve to rid the system of bubbles. Then I left it running overnight and came back to more bubbles. A friend suggested that suspended micro-bubbles in the water had simply gathered together to form larger bubbles. So I purged it again until there were no more bubbles. Left it running overnight again, yep, bubbles have returned. So that means bubbles are created while the system is running. And as far as I know, that’s the only time they’re created.
Attached is a pic. I’ll take a better one, but since the floor got poured today (the radiant system was running during the pour), I couldn’t get any closer. And yes, the tank and "system" are level, it's a crooked pic
From top to bottom I have the following: Out of the top of the water heater, hot side, there's a tee into the Air expansion tank (you can’t see the tank, it’s out of the pic over the top of the heater), the other side of the tee goes to the pump (pumping downwards), then the pressure-relief valve, then the pressure gauge, then the fill /purge valve, then turning right leading into the hot manifold, down into the in-floor Pex, up from the Pex into the cold manifold, up and back into the top of the water heater into the cold side. The air eliminator cannot be seen, it is screwed into the right side of the hot manifold.
I have never used shark-bites in my life, but used them for all connections. They don’t leak and all they grip onto is to 3/4 " Pex plastic pipe (no copper pipe in the system).
My one thought is: could air be leaking into the system on the inlet side of the pump ? It does use a Sharkbite there. I assume there is suction at that point, vs pressure on the other side of the pump ? Assuming there is suction at that point, would a Sharkbite let in air ? Do Sharkbites crave pressure but not do well with vacuum, assuming there is vacuum at that point ?
The thing I find overall confusing is that the system is under-pressure, by virtue of the pump in operation (although maybe not over the entire circuit, maybe there is a vacuum at some point(s)), so how could air get into a positively-charged system ?
You would think if the system is above atmospheric pressure, all’s it could do is leak, how could it **** in air ?
Or might it be because I initially used tap water, there's a fair amount of oxygen captured in the water and I might have to purge it multiple times ?
Any thoughts ?
Any thoughts ?
