What 5 tools did you use today?
joebachor
toledo ohio
matco 88 3/8" stubby, cornwell long handle 1/4" ratchet, snap on long 3/8" breaker bar,craftsman 1/4" breaker bar,gearwrench x-long rat. wrenches in 12,17,19 mm , various sockets, torch, various screwdrivers and pliers, wire strippers and crimpers, pick set and probably more that im forgetting. its my day off and I had some fun at home.
walrus
Maine
Screwdrivers, wire strippers, M12 impact, voltmeter, pliers
Sent from my XT901 using Tapatalk
Kev442
Wi
Work: T20 torx (a lot!), box cutter, machine cart.
Home: Flat bladed screwdriver, multifunction meter.
A quiet day.
ew1
putty knife, paint edger, paint roller, flat head screw driver, and heat gun
SuzukiGS750EZ
Cabelas version bench made griptilian, Milwaukee 6 in 1 electrical pliers, a wire wheel on a benchtop grinder and a snap on flat bladed driver.
pedrodagr8
Ut61e multimeter, husky pro screwdriver, soldering iron, flush cutters, tweezers
Sent from my EVO using Tapatalk
rodknock02
3/8 cordless snapon impact,3/4 1/2"drive Allen ,1 5/16 wrench and 3ft breaker bar. I work on fork lifts for a living
nicksnothereman
In the Mojave
I was mixing paint (actually blind color matching by mixing different paints) with a **** screwdriver. It counts. I'm crazy enough to do it and have it work out well.
I also used a leaf blower, rake, broom, and dust pan to pick up leaves. I was on a bit of a freetime bender today. That was between getting breakfast, going to home depot, getting a cup of coffee, going to walmart, plugging up holes in stucco, painting, doing laundry, drinking a bunch of beer and some whiskey and talking to birds. For some reason birds always come right up to me regardless of where I am. At home it's mainly mockingbirds, sparrows, and hummingbirds. I'm pretty sure they talk to each other about bird related stuff, I see grackels, sparrows, and blackbirds talking all the time. What does that have to do with tools? It don't.
littletoes
NE Washington
3/8" drive metric sockets up to 15mm, 1/2" drive metric sockets up to 32mm, ratchets to fit both, dead-blow hammer-2 lb, estwing engineers hammer, ball-joint puller, Snappy pry bars, flour jack, jack stands, trouble lights.....geez, might have been easier to list what I didn't use! ;)
Bikes&Bowties
Washington
12" adjustable wrench (proto). 3/4 impact (snapon). Random sockets (Matco). 24 inch 1/2 ratchet (Matco). Pocket knife ( kershaw)
Thumper68
Duluth MN
Lets see I installed 3 overhead paging speakers.
1) tape mesure
2) utility knife
3) jab/drywall saw
4) wire strippers
5) fish/glow rods
6) cordless drill
Light day only worked 2 hours as this job needed to be done after 4pm and we wanted to get it done to free up next week for bigger jobs.
The big question we are having is if we want to start on a few bigger projects Thursday and Friday or just wait till next week.
RaptorDuner
Randle, WA
Miller 304XMT with Miller 22a feeder, Empire speed square, ViceGrip (pre Erwin) C-clamps, Welpers, and Dewalt 5" grinder
flashman
Niceville Florida
Let's see.
1) Skil 3/8" drive corded drill (burned up today trying to mix thinset)
2) Dewalt 20V impact drill
3) Knife
4) Screw driver/Hammer
5) Trowel for plaster/thin set
6) Goggles for once in my life
Im working on a bathroom remodel. First time doing all of this. Found out my Skil drill I have owned for nearly 10 years was no match for trying to mix a bucket of thinset. Time to stop by Harbor Freight tomorrow and pick up their 1/2" drill for $50. Reviews are positive so even if it only lasts me a few uses it will be better than having to rent a drill from Home Depot.
893cv
Cincinnati Area
Supermax mill with Proto-Track mx2, deburring tool, bandsaw, bench grinder, indicator. I made 2 spent primer funnels for the reloading machines and a few motorcycle parts.
wilham320
I did a lot of wiring today... installing a vortec 383 with msd atomic efi in a 95 Chevy truck, so weller solder iron, Matco wire strippers, HF heat gun, razor blade, knipex diagonal cutters.
Brownsfan
Cleveland Ohio
Installed 6 remote starts today so: Wire strippers, Klein 1005 cutter/crimper, snap on butane solder iron, drill(with sockets and Phillips) and Klein true rms multimeter. Have to add a 6-7 snap on panel removal tool plastic and the standard metal one
SuzukiGS750EZ
I used my Shumacher battery charger on my wife's car battery (she plugged in her iphone in the car... overnight... )
Did she call you off said phone to let you know the phone was fully charged at the expense of the car battery?
