Best Soldering Iron
skruft
All the brands people are naming are perfectly good. I have used them. Which model or type and wattage depends on the sort of work you are doing.
I have and use a Portasol but do not use it very much because it is usually easy to plug into electricity.
Monte
Germany
www.ersa.com
pedrodagr8
Basically the soldering iron market stratifies itself into a few different levels:
Budget Tier:
I'm not calling this **** even though there are some **** offerings because most of the companies in this tier make stuff that WILL work for the average <10 times a year hobbyist . Most of the entires are based around Hakko 936 clones, with a few things added or removed. You can tell because they all use knock-off 936 irons a tips. Companies like: Atten, Aoyue, ZhondDi, etc. You will often seen known companies rebadge products from these companies. My first iron was a Hakko 936 clone and to be honest it served me well without fail for almost 8 years. I used it around 20-30 times a year.
Entry/Prosumer Level:
These are much higher quality. The fit between the heaters and tips are tighter, the quality of materials is nicer, they hold their temperature much better, have higher wattages, longer lasting tips, etc. You are very likely to see them on a pro's work bench but also might see them on an assembly line. Companies such as Hakko, Weller, Ersa and older Pace stuff are prime examples. The entry level stuff from each of these companies typically hits right around USD$100 and will last decades.
High End/Industrial:
These are the dogs nuts of soldering irons. They are meant to be abused, used 24/7 and make soldering as quick and easy as possible. Typically RF Induction based, most of these will make quick work of even the MOST difficult soldering jobs. Companies such as OKI/Metal, some Ersa, Pace and JBC (the best of the best at this time) are typically who you will find at this level. Expect them to be PRICEY (easily $500-2000) but if you need one then you know it. They often offer VERY thin light handles for easy precision soldering, LONG lasting tips, features to extend tip life, the ability to solder even the most difficult materials (such as to large copper ground planes), etc.
A bit of info about types of soldering irons:
Cold-heat resistive:
**** for electronics work, can easily kill static sensitive components
Butane:
These are decent for cordless soldering, temp control is borderline non-existant so its easy to lift pads and traces on a PCB. Much better used for splicing wires.
Ceramic Heater:
This is the most common type of soldering iron. It uses a ceramic heating element to heat a metal tip. Most budget and prosumer level irons use this technology. Temperature controlled irons include a themocouple in the ceramic heter or tip to control the temperature via a PID loop. The most common variant of this is based around the Hakko 936. It incorporates all of the needed features in a very nice reliable and inexpensive package. For this reason, it has been copied and reworked continuously in the aftermarket.
RF Induction:
This is the new kid on the block in terms of soldering. Its pricey but offers some very solid benefits for power users. RF induction works on the same principle as a induction furnace. A piece of metal is placed within a RF coil and the high frequency AC causes a rapid heating of the metal. In this case, the metal within the coil is the tip of the soldering iron. This allow for a rapid heating of the tip with heat times typically around 3-10sec from cold to full temp.
There are two different types of RF Induction in use right now. Fixed temp and temp controlled. Fixed temp was popularized by Metcal (now part of OKI) it exploits the Curie Point of the metal to control the temperature. The upside to this method is that for assembly work is you pick the right tip for the temp needed and its physically impossible for the worker to mess it up. Very useful in GMP environments. The downside is if you need a different temperature you have to purchase a different tip.
On the other hand, for temperature controlled ones. The thermocouple is integrated into the tip as with ceramic heater irons, and the RF is dumped into the iron until it reaches the proper temp. Most modern irons, like from JBC, can go from cold to set temp in under 3 seconds. This rapid heating now allows manufacturers to turn off the iron when it sits in the cradle rapidly prolonging tip life. This rapid heating also means that they can use low thermal mass tips (which cool down quicker) and higher wattages to compensate. Its not uncommon to see an iron running at 150W or more for short periods of time to allow soldering to large ground planes etc. Because they cool down quickly and shut down in the handle, the 150W is not a problem for tip life.
ndoran
^^^^^^ A good summary.
Years ago Weller used magnetic tips to implement temperature control. Each tip had a different curie temperature (the temperature at which a magnet ceases to be a magnet. When this happened a magnet switch opened and the tip would cool until the tip became magnetic again.
James_B
Nova Scotia, Canada (started in Brisbane, Australi
Pretty simple system, and easy to fix when it breaks ... which the magnetic switch will eventually do, either by burning out the switch contacts, or fracturing the pull wire that connects magnet at the hot end to the switch at the cool end.
The repeating soft click that the switch assembly makes as the magnet releases and reconnects is familiar to all those that have used Wellers, and that first click after switch on is an aural sign that your iron up to temperature.
The usual range of tips come in temperatures 600° F, 700° F, and 800° F (the back of the tips are stamped 6, 7, and 8). I have seen 5 and 9 code tips, but they aren't common, and to be honest, there really isn't a need for either of those 2 tips if you're dealing with normal solder. My only use for a #5 tip was to combine it with a cut down scalpel blade to make a nice hot knife plastic cutting tip.
When you've worked with Wellers for a while, you get pretty good at doing a tip change while the iron is hot. All you need is the right pair of bent nose pliers with serrated jaws, a level of manual dexterity, and somewhere to put hot pieces of metal.
CDD
A floating joke called Puerto Rico
In a past life, I used to teach "High Reliability Hand Soldering" The standard and associated course is the result of NASA discovering that the people employed by contractors didn't know how to solder correctly, and many components were failing due to poor soldering techniques. We'd spend a full week, teaching people that had been soldering for years, the correct way to do things. With examination of the student's practical tasks being done under a high powered binocular microscope.
There's a number of factors involved in the wires breaking right where the insulation meets the joint. Corrosive flux residue is one of them, the other is the solder itself wicking up the wire and causing a weakening of the wire at that point due to alloying.
Mechanical and chemical precleaning the wires and lug is important, as is the choice and amount of flux used (we used only rosin dissolved in isopropyl alcohol or pure rosin as flux), but the item that also helps the most is a set of the correct sized anti-wicking tweezers that will minimize the wicking of the solder.
Rosin flux is virtually nonreactive and noncorrosive at normal temperature, mildly reactive to metal oxides when molten. The fluxes to look for are "Type R (non-activated rosin)" and "Type RMA (mildly-activated rosin)". Type R fluxes don't require cleaning, and type RMA fluxes are not significantly corrosive, with post soldering cleaning being preferred but optional.
This is why I like GJ. The freaking things you learn here and the stories that comes whit it. :rocker:
This is why I hate GJ! WHY! MONTE WHY!? :eyecrazy: :thumbup:
eriksalo
Colorado
Most depends on your application. Brief advice is:
For connectors: Crimping is clearly better. It doesn't "feel" as solid but all the science say a good crimp is superior. If you are working on cars, learn to crimp.
Best Iron: The RF type (Metcal of old) is the best but is also spendy and only really needed for doing fine pitch work. If you have one of these, you also probably have a hot air re-work station. If you are asking, you don't need one of these.
Great: The old Wellers as mentioned in this post are really terrific but it's also made for fine pitch electronics.
Plenty good enough Iron: One of the Chinese units from eBay with a fine pitch iron and an included hot air gun will last the casual user a long time. Costs less than $100. This is also for fine electronics and if you are asking, you probably don't need one of these either.
General Purpose Iron: I find that for car stuff that isn't connectors (I crimp), I often need a honking big soldering iron. The fine pitch little things used for tiny leads on precision electronics just don't have the heft to do real garage stuff. For about $10 on eBay, you can get a powerful 100W iron that puts out some real heat.
Something like this, I really love mine:
http://www.ebay.com/itm/100W-Solder...084?pt=LH_DefaultDomain_0&hash=item417ae9313c
James_B
This topic prompted me to finally do something about getting a Weller TCP system to replace the ones I left back in Australia.
Picked up a new in box Weller TC201T solder pencil (with PTA7 tip) and a used, USA made, Weller WTCPT power supply from different sellers on eBay last week. Both were delivered in today's mail. Total cost including delivery was about a third of what a new Weller TCP system would have cost me delivered in Canada.
cheechi
Triad, NC
Mine looks similar to that one James, but it's not the same. it has a knob that I set the temp, are you saying yours is one set temp? or is that why the interchangeable pencils?
I'd have to look for sure but I think this is mine.
James_B
The TCP series Wellers are a closed loop system relying on a tip with a ferro-magnetic cap on the back. The tips are labeled 5, 6, 7, 8, or 9 and at that number by 100 degrees F, the ferro-magnetic cap reaches its currie temperature, and a magnet in the barrel is no longer attracted to the cap on the tip and releases a set of switch contacts. As the tip cools below the currie point, the magnet is attracted to the tip and closes the contacts in the heating circuit.
The 5 and 9 tips are rare, and not normally used. Here's a shot of 6, 7, and 8 tip markings:
You buy the tips by the tip style and the tip number. To change the temperature, you just unscrew the knurled nut at the base of the barrel, pull out the current temperature tip, insert the different tip, and refit the barrel. Once you've set the temperature by the tip number, it stays relatively constant, making a quiet click each time the magnet releases or engages.
cheechi
Triad, NC
neato. I 'knew of' that but hadn't seen it in person. Thanks.
I assume there's no 0.5 increment tips, then? 850 is a popular temp for some of the things I've worked on, same with 650-675.
James_B
Just the whole numbers in the tips. I don't know if a #6 tip is 600 or somewhere around 650. It's never worried me in 4 decades of TCP iron usage. I just know that for this job I'll need a #6 fine point, or for this one I'll need a #7 flat conical, or for another, I'll need a #8 double wedge.
These irons are normally powerred by a transformer that outputs 24VAC and have a 42Watt heater, but there are also 12V TCP irons that can be run off a car electrical system, and a version of the 24V iron designed to be run off 24V truck and military vehicles (a standard Weller TC201T solder pencil will also run off any 24V electrical system).
Weller also has a W60 and W100 series of irons that use the same curie point temperature control system (different family of tips) but with transformerless 115V 60Watt and 100Watt heaters.
