Anyone use a motion detecting switch to control air compressor?
healing
I want to avoid the air compressor running all night in case of a air line plumbing break by using a motion sensing switch that only allows current to the compressor if the shop is occupied. The motion sensing switch will switch a relay so current rating will not be an issue. I see they have adjustable programming from 5 minutes up to 2 hours. Are these motion sensing switches reliable?
I know I could just turn the compressor of when I leave but I would forget about it half the time. Thanks
mayday0017
Houston Texas
Thought about doing the same thing, I just got in the habbit of turning the ball valve to the lines each time before I go in. Depending on what compressor you have you can do what you are wanting for as little as $5-10.
icenfire01
South Dakota
This seems like a GREAT idea. I always forget to switch off the compressor and was thinking of making a dedicated outlet to the light switch but this would be much simpler. I have used this type of switch in a laundry room before and it worked great.
Davefr
OR
The only problem I see is if the relay happens to shut off power while the compressor is running. (maybe it didn't detect motion and timed out).
If that happens, upon restart the compressor will not have had the benefit of having head pressure bled down from the unloader valve which is triggered directly from the pressure switch. If the pressure switch doesn't toggle to off then the unloader valve on most compressors doesn't actuate to bleed off head pressure.
That could result in a failed start when motion is again detected. (possibly damaging the motor if it can't start due to excessive pressure). That could result in dangerous situation.
JakeKohl
Greenville, SC
I thought that the pressure switch would automatically relieve the pressure if the compressor was not energized? :dunno: I'll unplug mine tonight and give it a whirl. I like the idea of a relay off the lights tho...I'll probably add that to my to-do list when I rewire my little/old shop that I enter my new shop through.
Davefr
OR
I thought that the pressure switch would automatically relieve the pressure if the compressor was not energized? .
I don't think so (at least on mine). The pressure switch only actuates the unloader valve when the pressure switch breaks contact upon tank pressure reaching the cutout setting. (all mechanical based on pressure).
If tank cutout pressure hasn't been reached the unloader valve stays closed whether or not there's incoming power.
b-body-bob
Almost Heaven
Yeah it'd be worthwhile to figure out what kind of unloader your compressor has. Both mine have centrifugal set ups so when the pump stops turning, the pressure is unloaded.
Davefr
OR
mine unloads anytime i flip the switch to off, infact the past 3 or 4 i have had all have done that.
Yes, but if the motion detection circuit cuts power going to the compressor, the switch will still be on.
^^^That's the right answer!!
H
healing
Both the saylor beall and the gardner denver unloaded when I pull the plug during a cycle. So it looks like in my case it will not be a problem.
Ross/Kzoo
Richland Mi.
Nobody has answered the question if the motion detector switch can handle the ampacity needed for the motor load. I don't think so for most compressors it's a moot point
vhol5
West Texas
I guess you missed that...
er3456df
HVAC contactors are cheap. Can get one with 120vac coil.
Ross/Kzoo
Richland Mi.
Yes, I did miss it. I've had a motion sensing switch for my shop lighting for about 15 years. It's about 99.99% effective. For some odd reason that .01% of the time it stays on and resets itself to a different mode. That's probably been about 5-10 times in the last 15 years.
Regnar
You could also wire the Relay to operate like a 3 way switch by running a wire from the pressure switch on the compressor. If the pressure switch on the compressor is energized then the relay/contactor coil is energized. Once pressure is meet the coil would de-energize until motion is detected again.
:This is assuming the pressure switch is 120v!
b-body-bob
Almost Heaven
The lighting idea works but what about fixing air leaks so compressor doesn't leak or run.
Fixing the leaks is just S.O.P. but the motion detector would prevent the compressor from running constantly due to some failure - like the time I had a HF filter/dryer blow apart. I don't know how long it had been running when I finally noticed it, but it was long enough the insulation paper (no sheetrock) right at the leak looked burned. :willy_nil
I learned at that time to ALWAYS turn it off, and the lesson stuck. Taking that to heart like I did gives me the same net result as the OP is looking for out of the motion detector setup.
waggie
Upland, ca
it will probably take some programming, but, yes, it can be done. I used to install home alarm systems, which are, basically, just relays -- to the siren speaker and phone call to your monitoring station.
a better way would be to set up the relay to shut off your main air valve. that way, if your pipe burst, or leak, your compressor is still pressurized (assuming the main valve doesn't leak) and won't run at all.
taumac
Brooksville, Fl
I used to have a oiless machine that was so loud that a hated it to run so fixed all leaks so run as least as possible. Now, with newer compressor its just a habit.
The 5 Stitches Garage part 1 http://www.garagejournal.com/forum/showthread.php?t=142100
The 5 Stitches Garage part2 http://www.garagejournal.com/forum/showthread.php?t=211899
LS6 Tommy
Northern NJ
I had a posting here yesterday that seems to have gone missing. LOL.
You can remove the unloader from the pressure switch & install a combo check valve/unloader. They always bleed off after the pump stops, regardless of whether the pressure switch is made or not. Those Schrader style unloaders on the pressure switch invariable end up leaking anyway.
I also have an SOP that's burned into my head. I leave my compressor tank charged, but shut the lines down. Last thing I do before leaving the shop is where force of habit comes in. I've done it so many times now it's clockwork.
1. Turn regulator down to 0.
2. Turn compressor operator "off".
3. Drain condensate from tank.
4. Turn off lights.
I used to leave the stereo amp on all the time and my shop clock has a fluorescent light in it, so I plugged the light into the switched outlet on the amp. If I walk by the garage door & see the light on, I know I left the amp on.
Tommy
nehog
Jaffrey, NH
Do not use an automatic switch like this on a compressor.
Say the switch triggers off while the compressor is running, almost at the shutoff point. The unloader won't trigger, leaving full tank pressure on the pump. Then the automatic switch triggers on, with full head pressure, and the motor won't have power enough to start. At that point something has got to give, and it probably will be the motor.
Davefr
OR
That doesn't address the scenario where the compressor itself fails, leaks down and then runs continuously until it throws a breaker or self destructs.
I'd venture a guess that this is far more likely then a downstream line rupturing.
fteufert
Near Scranton, PA
Have you considered a timer, like one used for a bathroom fan?
I am installing one on my compressor since my son always forgets to turn it off.
pepi
Woodstock, GA
I think the BEST solution is to find and fix the air leak, or just put a sign up on the door you exit the room from reminding you to kill the power.
You're going to create a bigger problem trying to solve a simple problem, automation is a fine concept. I will assume this is a 220 machine and would suggest a timer, the same type used for pool pumps of course 220 rated.
My compressor and not bragging btw stays on 24 x 7,365, unless I am using it does not run period, it and supply piping are a 20 + year installation to be clear.
To continue there are some screwy statements above please read:
Air compressor unloader valve.
The output of the piston compressor is connected through a pipe to the air tank. When the compressor stops, the pressure in this pipe is blown off to 0 bar (atmosphere).
This is the ssssssshhh sound you will here when the ccompressor stops for whatever reason. At the same time, a check-valve makes sure only this small pipe is empty and allows the air receiver tank to remain pressurized
Why? When the compressor starts up again, and this pipe would still be under pressure, the electro motor will not be strong enough to turn the compressor.
In other words the unloader function has nothing to do with the power, strictly a mechanical function .
Milton Shaw
I would suggest using a relay off the light circuit. A lot more dependable and usable than any kind of motion detector. I would also suggest a solenoid on the outlet of the tank to cut air delivery from the tank when the light are off. If you got a relay with "NO" and "NC" connectors you could wire additional smoke detectors to turn on when the shop is empty and the lights off. Smoke detectors on all the time in a shop that has welding, running cars and other smoke producing jobs will be going off all the time.
Spareparts
Lansing Ks.
The only problem with a holding circuit confrigation is the compressor will not build enough pressure with a major leak to shut off automatically so your back to step one. I just added another light switch above my light switch for my shop lights, when I leave for the day/night both switches get turned off.
Davefr
OR
This is not necessarily true. At least with many compressors including mine.
What actuates the unloader valve to fart off pressure is the pressure switch toggling to off when the tank is full. (100% mechanical via cable linkage)
If you stop the compressor by killing power and the tank is not full then pressure will not be "unloaded". (ie there is no ssssssssh unless the pressure switch and only the pressure switch turn off the compressor.
sberry
Brethren, Michigan
I have 2 comps, finally figured I didn't need the breaker on to the second. I use all the tanks, about 200 gallons. I have a shady hose or 2 due for replacement and have a couple things isolated via valve.
Mine is on 24/7, never totally shut off. I had a regulator problem a while back and in a hurry to fix simply added a t and a hose as a jumper. Today I finally picked the pieces up and drilled out a broke ******, repaired it like its sposed to be.
I leave a lot of it live, never had it happen. Have always managed to pre empt finding a leak but have one outdoor that is decades behind its service life and I should replace the feed hose to my steamer.
A small garage doesn't need gobs of connected equipment. Keep it in good shape. I unplug tools from hoses to prevent leaks. So much of it is coupler related. If its not leaking its not running.
jcouch1
Louisiana
why not use the timer to shut down compressor and close discharge line so that you never run the compressor and always have a full tank!
Good ideas.
I put a 120v solenoid valve on the line of a compressor to function as a bleed down. old centrifugal bleeder broke, so we took the parts out and used the electric valve to fix the problem. Been running good for several years now.
