mx842
I'm working on putting plans together for my wood burning boiler stove and as usual I want to use materials I have on hand for as much of the build as possible. I have some really nice 316L stainless tube that I want to use as boiler tube. My plan is to cut up the long sections into different sized pieces and fab a box out of it.
The material is roughly 9"X4" outside with a wall thickness of 1/2". I should be able to get roughly 40 gals +/- easily around the firebox just from the sides and top. If I have enough material I could add tubes to the floor also to get a few more gallons out of it.
I have some 316L Ibeam that I plan on using for the base which is 10" high with a 4" flange and I was thinking about using this to sit the wood burner on, then I got to thinking why not box it in and use the footprint as an additional storage tank. That would give me an area of 10" high by 4'X4'. I haven't done the math on it but that should give me a pretty decent supply to work with to heat my floor.
I know I need a bunch of other things to get this going but what I was wondering was is how well do you think this 316L stainless is going to hold up in the firebox?
