Just wondering. Are they lost? broken? or just dull?I lent someone my set of cobalt drills and now I need to replace half of them.
IIRC SO has a lifetime warranty on their drill bits.The smaller ones are chewed up, the larger ones are blue and dull. Turns out they were drilling holes in stainless using a lot of pressure and high speed.
Are there different kinds or grades of cobalt drills? I paid a lot more than $25 for this set of S-O drills thirty years ago. I can't imagine the Sears set is as good, or am I wrong?
This thread reminds me of why I hate lending all but my most crappy tools.The smaller ones are chewed up, the larger ones are blue and dull. Turns out they were drilling holes in stainless using a lot of pressure and high speed.![]()
There are different grades of Cobalt HSS. M35 and M42 are the most common alloys. M42 has a higher amount of Molybdenum. There are also different flute geometries depending on the alloy types the drill bits are meant to drill.
Are you sure the drill bits that are blued are actually ruined? Cobalt steel is supposed to take the type of heat that can turn regular steel blue. Also, one of the problems with drilling stainless is galling where metal transfers from the alloy being drilled to the cutting tool, which in term increases friction and heat. You might want to try regrinding the tips and check the drilling performance, at least on a couple.
Wouldn't hurt to give'em a call....
I assumed if the bit is blue, its lost the temper. I could try sharpening them.
What is the difference between the alloys?
ywI'll do that! I assumed bits were consumables that were not warrantied. Thanks dirty dog!
I have also had some good luck with these bits, that I picked up at the local hardware store:
http://www.artu.com/drillbits.htm
yw
Apparently SO does warranty consumables.... like drill and driver bits, saw blades, taps and dies.... at least that's what a SO lady told me over the phone a coupla of months ago
The bits are consumable and would not be replaced.
Thank you,
Snap-on Tools
