The VISES of Garage Journal
bluebolt
Benton LA
New here, I've picked up a few vintage vises lately and looking for information on them and found this great forum and thread.
I have 4 in total, Columbian 5 1/2, Chas Parker 22x, Morgan 140 and now a Morgan 160. They are all in very good working condition. I'm trying to find out the age of the Morgan 160. It is a Chicago vise and quite heavy. I will post pictures soon. But any info on the 160 would be appreciated.
Chicago was the first place they made Morgan's from mid 1920's to 1947 when they moved to Aurora.
gregthor
MICHIGAN
Thanks guys for the kind words on the Wilton resto a few pages back!!
454ragtop – About the carriage bolts for the swivel, I usually wire wheel them also but in this case one was bent. You can’t see it in the photo though so I just decided to replace both.
Ritzblitz – I would like to learn more about your handles. Did you post a thread about them on GJ?? At the moment I am going to leave the chipmunk chewed handle as is since it is not bent. But I have 2 other vises on the “to be restored pile” and both have badly bent handles. What sizes do you offer and how is the ball installed?
Thanks, Greg
BFBOB
Thanks, Greg
And you didn't straighten it? Like, in your brand newly restored VISE!?!?:headscrat
90zcar
All this talk about vises....anyone have any opinions on some jaw pads. I have always used old pieces of rubber or foam to do such the thing but I see online they sell urethane jaw pads. They look like a L shaped angle iron lookin rubber pad. Can these be found at any stores?
drivesitfar
I buy 6 inch copper Wilton brand ones off of Ebay from Bob and Maureen for $30 that work great even on my 4 inch vises if I don't want to damage the item i'm working on or my vise.
TreePointer
PA
Lowes carries these: BESSEY Nylon Magnetic Vise Jaw. I use them quite often.
Try some internet searches using VISE JAW INSERTS and the material you wish to use.
Provincial
Near Salem, OR
I have made jaw covers for my vises from some scrap aluminum sheet for years. I have used both 5052-H32 and 3003-0 (dead soft) in .060" and .050" thickness with success. Because they are so thin, they wear quicker than a store-bought cover, and they work-harden enough that by then time they are dented and worn badly, they have become prone to cracking. I find that they do a great job and don't damage delicate materials.
I will be buying a set of copper covers for at least one of my vises, and probably some sort of plastic covers, too. I am interested in reports of what type of plastic gets a good grip while being soft enough. Many types of plastic are quite "slick."
autopts
That's a great idea. I've been buying and using their liners for a long time, when it was raining bullets years ago. The faces are so thick they will last almost as long as your vise. Also, the oversized copper shrouds give the jaw towers added protection. Good move
Trimming down the sides and hold down straps with a hacksaw is easy. Round out the ends of the hold down straps so when you hit them down, they won't scratch the paint
Mark in Indiana
Southern Indiana
I use lengths of 2" x 2" x 1/4" aluminum angle stock. It works for me and it's cheap.
Wrapping a work piece in rubber or a similar material is great also. I do that when I'm clamping a
Lead screw / handle in a pipe vise for cleaning & polishing.
hemdale
France
Hi guys,
Sorry for my lack of knowledge but it seems that on Leinen vise, the moving part is the rear (rather than the front). Does it make any difference while using it ?
As far as I'm concerned I'm thinking that the vise will be more on "top" of the bench (don't know how to explain...) rather than a "bit off the bench".
Also, they come in different widths:
Width of jaws: 60 mm
Opening max: 65mm
Depth max: 32mm
Width of jaws: 80 mm
Opening max: 100 mm
Depth max: 32 mm
Width of jaws: 100 mm
Opening max: 140 mm
Depth max: 70 mm
Width of jaws: 125 mm
Opening max: 175 mm
Depth max: 75 mm
Width of jaws: 150 mm
Opening max: 250 mm
Depth max: 87 mm
Weight: 53 kgs !!!
What do you guys think usually have ? I'm under the impression that a 100 mm would work fine as an allrounder ?
drivesitfar
That looks like a great vise and have never seen that brand before. your usage will always determine what size vise you need and my take is get the biggest one you can and maybe have a smaller one as a backup on another bench.
Polish vises also move this way and are one of my favorite vises. if you are using materials that go to the floor it can be difficult, but if everything is in or above the jaws this style is a winner if you have a little room on your bench.
Autopts: I've never actually loaded a bullet in my vise. does the vise shoot as straight as my Winchester or will the copper jaw covers help with alignment?
Monte
Germany
Hi guys,
i own a Leinen vise in 125mm and in 150mm, a Heuer in 100mm and 2 Peddinghaus in 135mm.
I think if i only could choose one vise size i would go with a 125/135mm vise.
i wrote something about the differences in vises here in post #845:
http://garagejournal.com/forum/showthread.php?p=600834#post600848
some picture comparisons are here @ post #2217
http://www.garagejournal.com/forum/showthread.php?t=28952&page=111
If the moving part of a vise is in the rear you can only clamp work pieces up to a certain width/depth because the work bench will be in the way so it depends if you have to clamp unusual large objects or not. Of course vises which open to the front have a limit too. But in like 95% of the cases i think you won´t have a problem.
turbowoodworker
Apex NC
I am posting pictures of my recent find at a Habitat Restore. A Prentiss 512 with 3" jaws for $35, no hagelling at the Restore.
I have been through about 450 of the posts on this thread and only found one other 512. Any idea on age of this vise?
Some decent hacksaw marks on the top of the jaws but overall in good shape. The press fit device that holds the screw in place had the one important tooth broken but I was able to rotate it and take all the slop out of the mechanism.
Fun little project for a quick, first restoration.
On the back of the static jaw and the underside of the slide is stamped "1 02". Date stamp? I can't figure it out. I can't imagine it being 1902 or 2002, so what gives?
turbowoodworker
Apex NC
Here are a couple of "after" pictures from my 512 posted above. For some reason I can only download pictures from my old, broken Canon camera and not from my shiny new Canon Christmas present. Guess it's time to read the manual.
boomer12831
northern New York
I just received my new little vise from a fellow GJ member. It will be a great addition to the other 3 that I own. The red one is one that I restored 15 to 20 years ago ( before I knew that people actually did that ). It is time for a complete sandblast and repaint. The little one will get cleaned up and painted also. Would anyone have any info about these 2 vises ? I am always impressed with people that know about the history of some of the older tools. My Wilton Bullet will also get an overhaul as it is sitting in the shed just waiting for warmer weather when I can get the sandblaster out. Ed
EOC_Jason
Bentonville, AR
You should be able to find a few images of old desmond stephans catalog info. I'll try to post some tomorrow as I keep that stuff on my other computer. They eventually sold their vises to the Ridge Tool Company (aka Ridgid), which kept a similar design for a while. They are good solid vises, I'm still regretting selling a 43P I had, but I have several Ridgid's so I'm not at a complete loss.
marvinlee
Hemdale, you are right: the rear jaw does the moving. I like the Leinen vise design (a few other brands are like it) because larger work pieces are held over the stationary part of the vise base, which in turn is fully supported by the work bench. That has always impressed me as a better engineering design. The advantage of the normal kind of vise, however, is that all or part the workpiece can be held over the floor for easier viewing and metal working. Do any owners of both types care to comment on which design they prefer, and why?
Krr1967
I picked up this vise a few months back but don't know what brand it is , it has no markings on it . I was wondering if anyone here might know something about what it was or how old it might be ???
The Boss
Connecticut
This one belonged to my Grandfather who worked at the Springfield Armory as a machinist. I rescued it this past summer from my father's house after a pipe broke - flooding the basement - it was stored under the oil tank. ;)
GETRIDAONE
Auburn, GA
Athol Machine Company sheet metal vise.
How are things on the PY forum. My last visit I see you are the proud owner of a "Super Duty" now.
drivesitfar
really nice save on the old Athol. looks a lot like my Prentiss coachmaker's vise. interesting size holes to mount that nice vise to a bench and i'm guessing it might have been on that board for a while with slotted screws holding it down.
flemrasm
Hi all, i have bought an old vise and i cant find any info on it, it has the letters RB and number 7 on it, im guessing its a 7", its really huge and weighs 85kg, anybody who can help?, im planning on refurbishing it and then it will get a Proper post here
[/URL]
[/URL]
[/URL]
jpickar
Now that is cool! I am a gun nut so that vise means a lot to me! What did you grandfather do at the Springfield armory?
John
EOC_Jason
Bentonville, AR
As promised, some images I have on the Desmond Stephans vises...
bl00
Chantilly, Virginia
flemrasm,
That's an unusual vise you have. It looks familiar, but I can't find any info on it in my vise file. Make sure to take pics when you have it apart.
GETRIDAONE
Auburn, GA
The thing I noticed was the odd pattern on top of the jaw. I have seen it recently but don't know where. The Precision Streamliner (airplane ) vise has a similar pattern on the jaw.
The Boss
Connecticut
It's not a real Super Duty, it was built as a show car in the 70's and a Super Duty motor was built for it and installed. Subsequent to that the motor was harvested to go into a real SD car being restored & I'm in the process of building another to go back in it.
The Boss
Connecticut
John
I don't know exactly but know he also worked at the Indian Motorcycle plant for a number of years and was hired by Rolls Royce of America when they opened their plant in Springfield, MA.. My Father also worked for a few years at the Armory, I'll have to check with him what they did there.
Quickpick1
I don't want to intrude on anyone's conversation, but could some
one educate me on a vise I have setting in the garage?
It is a Ridge Tool Company No. 61
454ragtop
Carver, MA
It's a good quality, made in USA vise, definitely has some value. How wide are the jaws, and what part of the country are you in? Values can vary depending on how hard vises are to come by where you are.
HTH, Jim
Quickpick1
By width, if you mean from side to side the jaws are 6". if you mean opening front to back I didn't open all out, just opened 6" then measured the remaining slide which was a little over 4 more inches, so I'm thinking 10" total opening front to back. I live in southern Kentucky. I've had this thing sitting around for quite a while, always meaning to put it on a bench, but I've gotten older, Sold the farm, so I don't need this monster anymore. I need a smaller one.
I was quite surprised to see that there are vise collectors out there, I'm curious if this has a collector value or just a plain, big, common vise.
I'm also guessing weight near 100 pounds
zoomieport
The Mall City
I think this is a job for EOCJason...
But I believe it's a Desmond Stephan #61, rebranded for the Ridge Tool Co. (Ridgid)...
As far as value... A lot of that depends if you are talking eBay or Craigslist.
It's not extremely rare, odd or the like, but it's pretty big, so it's worth a few bucks... (Maybe more to a collector specializing in Ridge vises)
Take care!
ZOOM
