Preface: I'm renting a garage for the next couple years and I'm setting it up for a hobby metal fab/motorcycle workshop. The property is about 100 years old and has all sorts of relics of work past.
In trying to sort the wiring out, I came across two panels in the garage. The house is powered off a different panel in the basement. One panel in the garage feeds the auxiliary structures and one outlet/light in the front of the garage that the owner has used for an air compressor and an exterior light on the front of the garage. The question I have is in regards to this other panel.
There is a very old, small load center, which connects to a meter box just outside the wall. This meter box is off. Apparently the owner had the service turned off because it wasn't being used.
This is the meter:
This is the load center:
Am I correct in assuming that this is evidence of 100amp service from that meter?
I was thinking of removing that panel, and replacing it with a small, 6 space 100amp load center like this:
http://low.es/196itCI
I would be using it to power (1) 30a 220v circuit for a welder, (2) 20a circuits for lighting, and (2) 20a circuits for outlets.
The owner is cool with me having the power turned back on and then I would be paying for my service directly, and not having to figure out a portion of their electric bill.
Am I missing anything here?
This is the meter:
rate schedules and AG-1 is way higher than that. Plus, the OP wouldnt qualify because it would be for single motor load(ie a pump) which he doesnt have!! Also, the tariff schedule says 70% or more of the annual energy use has to go towrds agricultural end uses. Read the following for more detail:
