I'd love your thoughts on the CMS once you have some time with it.
Yes. I need to really understand it before I pass judgement. One thing I don't like right now is the lack of a fine feed adjustment for the whole fence. I think I have an idea on how to fabricate a fine feed but I'm learning to work with it.
I really like the drawer joint but am worried about the two plies left in your rabbet delaminating.
No worries, I appreciate suggestions and insights. I think for my future ones I'll go just a bit shallower. I try to match the rabbet to the depth of the dado for the drawer bottom so that the dado is then hidden. I don't think it will delaminate - certainly not at the glue joint (waterproof glue) and it's unlikely it will after the drawers have been polyurethaned.
TAre you going to put a front on the drawer box?
You might want to soak the exposed ends of the dominoes in a dark stain before installing to add some extra contrast.
Why yes I am. And I did think of that and was considering actually milling my own dominos (I have a kickass router table now) but I think you need to draw a line in the sand and milling my own dominos
is that line. You can buy Sipo ones which are darker but I don't know that I want to do it yet. I'm still thinking about it.
_ _ _ _____________________________________________ _ _ _
It feels like it was a very productive day and yet it seems like things took forever. Today was all about the drawers for the upstairs bath. While I could have started on the cabinet boxes I felt that finishing the bath drawers might inform me on things I could learn for the kitchen.
Something I'd picked up from TimTool on the Festool forum was his very simple approach to drawing lines. Since I knew I was going to have to notch the back of the drawers to allow for the drains I decided to make it a "detail" by creating a nice symmetrical cut that would work on both sides. I traced the 150mm sanding disk and then used the width of a handy ruler to set the taper.
In order to not have to cut off 8mm of extra tenon I cut them a bit shorter. After doing this once I realized the easiest way to do it was to simply clamp them in a Bessey clamp and lop off the ends.
I've also gotten the hang of how much glue to use so I'm getting very little squeeze out. As I finish one drawer I clamp it up and then build the next one.
Once I'm done with building the next drawer I go back to the clamped one which has had enough time to dry and I bore the mortises with the domino, glue up the domino and tap it home and wipe off the glue. While that's setting up I run the small trim router all around the inside and out of the drawer edges with a 3mm roundover bit (like an 1/8) and then I run a sander over the edges and the dominos to flush them out.
All the drawers installed fine (and yes, one is slightly larger to account for the lack of plumbing on that side) but these fancy pants Grass soft close under mount slides are taking a bit to figure out. Thank god I only got the 2D versions. It still took most of the afternoon to build the drawers and get them in. This was 3pm but I wanted to get more done.
_ _ _ ____________________ Intermission ____________________ _ _ _
Since people seem to enjoy my random tips here's one for the truly OCD crowd...
Washers have a front and a back. Yeah, didn't know that either when I was learning my fabrication chops but much like when I was learning to be a photo assistant and I was stopped for coiling a flash cord the wrong way my friends tipped me that all washers have a front and a back and they should be installed correctly. Obviously you don't have to do this - you'll never know but if you're a particular ******* you might like to know the "right" way as it was taught to me. Asleep yet?
So the one on the right is "front" up. It has a rounded edge from the stamp pressing down. The one on the left is the back as the edge is sharper from being sheered. The way to install them is with the rounded edge facing out so the sharper edge is in contact with the material. This comes from the tradition of chamfering all outside edges since that edge is softer and looks better facing out. It's like the way that top level machining always chamfers the edges - even though that's mostly done for stress reduction. Installed it's like this:
Note that the Kreg delrin washer is chamfered as well.
I took this to heart and have always done it since. I think it's a detail that one ace fabricator does for the benefit of another ace fabricator to appreciate but that no one else notices. I like details so it appeals to me.
_ _ _ _________________ Back to our Build _________________ _ _ _
Instead of edge banding the drawers I decided to try to edge them in solid walnut to see if I liked it. I
do like it but it was a tedious pain in the *** that took almost an hour a drawer to do for some reason.
I'm unsure if I'll do that on the kitchen as it was time consuming and I don't know if it adds anything to the whole. I may go back to traditional edge banding and then trim down the bevel to be less conspicuous. Or possibly do it another way that I haven't considered yet.
Either way I'm done with the bath. Sure it needs to be poly'd but I can do that when we've moved in - right now I'm going as fast as I can to just get to the "livable" stage. New projected move in date is now Valentines day!
Gregor
