buildmyown
I screwed up was putting one of my snowmobiles back together with a new top end. Broke one of the cylinder bolts off in the block on the final round of torquing them down. No idea how or why they are only torqued to 45ftlbs. I drilled it and went for an easy out but it would not budge so i just kept drilling it out bigger and bigger i thought i was drilling it straight but with the motor mounted on an angle i was not. With the weather changing i said screw it and pulled the motor out and brought it inside.
Option one make a jig to hold the motor level and square in my drill press and use one of the other holes to index off off and drill over size and time sert it.
Option 2 split the case and give it to a friend of mine that works in a machine shop and let him do it in the bridgeport,
Option 3 if i can find a long enough drill bit in the right size i could use the cylinder as drill guide.
That is how I would repair it, plunge down with a short 4 flute. The hardest and most time consuming part is going to be getting it jigged up properly.
