EarlyBroncoGuy
King Of The World
- Joined
- Aug 15, 2013
- Messages
- 926
Almost done erecting a 2400 sg ft shop, now I need to start planning how to wire it. First off, I'm no electrican - I understand and work on automotive 12v DC circuits with no problems, but once things start getting into AC and multiple phases, I admit my limitations. The basics I get - voltage, amperage, resistance, inductance - but I've never bent conduit or installed a panel.
The shop is new construction, metal building on concrete slab with fiberglass insulation on walls and roof. We're out in the country, have a pole on our property that serves the house, it's about 300 feet away from the shop. Would it make more sense to have the power company run another cable from that pole to the shop, or should I dig a trench between and run underground? Here in central Texas, frost isn't a problem.
The shop will be mainly used as a storage garage for my stuff, but I do plan to install a 2 post lift and do repairs, maintenance, and some light fabrication/restoration work out there. No heavy equipment or tools, just the basic drill press/bench grinder/welder/comprssor power tools. Shop will have 3 large doors which I'll open for light and ventilation most of the time, and skylight panels in the roof for some additional light, but I'm open to suggestions for additional lighting. Ceiling is 16' at the peak.
I'll probably never use all of it, but it's been suggested that I go with 200 amp service, since it's new construction and might as well go bigger than I think I need and be able to grow into it. Mainly I'm looking for advice and ideas on the most efficient way to run conduit inside to the various outlets once I decide on where they're needed.
