must have alignment tools?
gsingh
NOVA
Are there any tools that you guys have to have for alignments or any tools that make alignments much easier?
smogtech
flank drive plus wrenches, propane torch, pb blaster, air hammer, water pump pliers, 4 ft pipe that fits over your flank prive plus wrenches. that should do it.
Ruger_556
Two pieces of aluminum channel about 4 ft long with a string and fish hook on each end. Cut slots in the end for your two tape measures and do your toe settings by yourself. Just hang the channel above the bulge on the tire on each side. That an angle gauge and a roll of string and you can align any truck or trailer.
G
gsingh
NOVA
I do alignments at work, and just wanted to get some ideas about making them a bit easier.
Already got a hunter rack, FD+ wrenches. Might have to get some pipes.
devoncoolman
quakertown pa
Knipex and pipe wrenches. The snap-on pipe wrenches make it easier at times. The otc tie rod adjuster set is nice for trucks
00S4Boy
It all really depends on what your aligning.
Claws for vans/trucks.
Pipe wrench's for trucks.
Wrenches/sockets for cars.
Torch.
turdferguson13
Stubby wrenches. I did an alignment the other day where I could loosen the eccentric bolt easily but the other side of the bolt was out of sight and I could only fit a stubby wrench in.
What is a claw?
SS5150
NE IL
I've found my Snap On high perf box wrenches handy for Libertys and the rear on Caliber/Compass/Patriot.
AndrewV
Fl
Everything they said, and some patients.
But the musts.
Tie rod sleeve adjusters(claw set)
Sockets/wrenches
The seldom used prybar
Cordles 1/4 impact for stupid undercarige pannels
And the most important thing is knowlage. As in cam bolts working in tandum, how to adjust for torque pull.
But thats mainly it. Ebay hunt for what you don't have, it would be cheaper.
jjb
Minnesota lakes country
I use these alot. You can grip extremely tightly with them on inner tie rod ends.
http://store.snapon.com/Pliers-Wrench-Wrench-Adjustable-Pliers-1-3-4-jaw-capacity-P640879.aspx
Also use this wrench on GM fullsize trucks for adjusting camber & caster. It is extra long so it offers great leverage.
http://www.cornwelltools.com/webcat...d-21x22-Metric-L-MD-Ratcheting-Reversible-Box
looks like this but has 21mm and 22mm sizes
http://www.ebay.com/itm/Cornwell-CR...81568677?pt=US_Hand_Tools&hash=item565a439fa5
BearCuda
Martinsburg,WV
Milton Shaw
Older models are where the specialty tools come in handy. A lot of fords required special tools to move the adjustable control arms for caster camber. Some front drive require torx bits to shim rear spindles to install shims. On the fords there were special tools for mustang II's, crown vic's, etc to set camber/caster. When you get into replacing parts worn before alignments you will need some pickle forks and ball joint press sets etc. But start off with what has been mentioned above. Whenl you run into the cars that need specialty tools, then check Ebay and here for sources of specialty tools not being used by retired mechanics. Truck and heavy duty take an entire different range of tools to set them, like I said it depends on what you run into.
One of the most important is a brain. Look at the tires coming off for tire wear and problems, recognize the patterns for toe and camber wear and adjust the cars to eliminate the wear not just to be within spec's. Also doing this you can also recognize when the alignment heads have been dropped and all the cars are the same amount off on the same wheel without tire wear to back it up.
chris142
apple valley,ca
Anybody else still have there volarie prybars for moving the upper a arm shaft to align those turds? Mines with my other unused things like the olds cv boot installer and my northstar wp socket i used once.
