You're gonna move the Monster garage? I sure hope you will still do updates and everything else. I don't think it will be the same when you start posting out of a new place.
No chance of you adding on to what you currently have? If you could add on a couple of thousand square feet to the current place, you'd be much happier than having to drive somewhere else to work on things. Plus if you stay where you're at, it's going to be a lot safer as far as break-in's go.
By the way things look, you'd have enough room to add on, or add up, beef it up, and add an elevator to move cars from the lower area to a clean room upstairs for assembly and upholstery. I know for a fact after seeing your builds on everything that you could pull it off.
