start of the day
goes (L to R) good wood table, upright plywoods with red box in middle
little'r flimsy table then good metal table
the part that i am going to change
another shot of the plywood uprights, been there long time
used the bobcat to move the red box over to the metal table
everything in the middle out and the two plywoods now cut to length forming
a new table top, so 2 pieces of 3/4 screwed together.
Also upright from now disassembled flimsy table used as upright on new medium slightly junky table.
built this guy, actually first sort of measuring it to make sure table would fit over top
so the sawhorses can fit underneath and in the back
after a few adjustments it fit, had to turn the left rear 2X4 upright
basically pretty happy w/it.
I can see i may add a piece of metal on the front edge for stability.
Lots of tools all stacked up on the counter space which is exactly what the uprights were preventing.
BUT i fix all that later.
I WANT that table area going right across as a trial for a couple years.
turns out my two wood blocks could sit one on either side leaving room
for a small roller cabinet to sit in the middle underneath.
The dolly for the sawhorses has the notching in case a little roller cabinet ends up there.
and the pieces that came out from holding the tool box in the middle and holding the plywood so it couldn't move.
near the end of the day
pics a little dark
All you GJ posters ( especially w/ pics ) keep up the good work!
Great inspiration
