signcrafter
- Joined
- May 9, 2012
- Messages
- 12,680
Anyone have experience with one of these, http://www.gearwrench.com/gearwrench-3289-oil-pressure-check-kit.html. I've been looking at oil pressure testers for a bit now and have been looking at the standard ones with a gauge and hose and a few fittings or adapters to hook into the oil pressure sensor spot to read PSI. Came across this thing the other day and it looks interesting.
Do you just take the oil filter off and then screw on the right little adapter to the ****** on the engine that the filter normally screws onto? Then screw the tester cap onto the little adapter and hook up your gauge? Does the oil go through the slots on the little adapters and still go through the engine?
Would this be better or quicker then a "normal" oil pressure tester? Or are there some vehicles that a normal oil pressure tester won't work on and you have to use this filter adapter setup to get oil pressure?
