AndrewH
Hey guys, I've been looking to upgrade my 8 gallon Harbor Freight air compressor. It has served me well but now that I have a garage and have a place for a semi-stationary compressor I'd like to upgrade. I've narrowed it down to 2 choices:
HF 2HP 29 gallon compressor
$329.99 with coupon
5.9 CFM @ 90 psi
150 psi max
http://www.harborfreight.com/2-hors...-iron-vertical-air-compressor-68127-8026.html
Or..
Sanborn 1.6HP 30 gallon compressor
$377 with 10% off coupon
5.5 CFM @ 90 psi
135 psi max
http://www.menards.com/main/tools-h...portable-air-compressor/p-1655325-c-12910.htm
I am renting and I'm unable to wire the garage for 240v so that's out the window. I like the price of the HF model, and the 150 psi max and the higher CFM though I've heard that might be slightly inflated. On the Sanborn I like the twin cylinder pump, the 2 year warranty and the fact that it's able to be wired for 240 when I do own my own place plus it's 1 gallon larger.
So out the two which one would you guys choose? I appreciate any and all advice, however a larger compressor is not an option both financially or space wise. Let alone the power requirements.
$329.99 with coupon
5.9 CFM @ 90 psi
150 psi max
Or..
5.5 CFM @ 90 psi
135 psi max
