bcrewcaptain@
- Joined
- Nov 11, 2007
- Messages
- 19
not sure where I even got them, but I use a couple sets of these in the toolbags
I suppose in my line of work, as a diesel mechanic, it has never been a huge concern to cleanly cut a zip tie. Heh
I once worked at an off-road (Baja type) fab shop and we were nearly fired if we didn't cut them flush. Usually with the flush cut dykes or a razor or box knife.
Best wire tie tool I've ever used. Had it for over 25 years (!). T&B WT2-TB. Smaller than any of the guns. Squeeze it like a syringe until you get the tension you want, hold the tension on the last squeeze & twist. Cuts it off flush...
Tommy
One of my all time favorite tools, Channellock No 357
Large toe nail clippers!
I pride myself on doing things with precision and as clean as possible. However, am I missing something by not making sure my zip ties are cut nice and flush? (That's kind of a serious and fececious question at the same time). I have always and for everything cut my zip ties with a pair of dikes. C'mon my fellow garage junkies, what am I missing? Only thing I can gather is the small potential that someone will cut themselves on an uncircumcised...ah em...uncut...ah em...non flush cut tie.
Regardless, I do like the look of those revlon eyebrow/cuticle/nail/toe hair cutter. I could see that having many uses. Kind of like the hair dryer I just swiped from my wife. Perfect for those jobs where just a little heat is enough.
Electronics cutters:
Have any of y'all tried cable lacing?
For standard everyday cable management its awesome, plus since you do not have the plastic head of the zip tie, it is about as flush as you can get.
1st I've heard of it, can you explain ?
What a disappointment . You know that giddy feeling you get when you order a tool ;-)
http://en.wikipedia.org/wiki/Cable_lacing
Lacing cord is used a lot in telecommunications and aerospace. I learned it doing power in data centers. On my projects I use it wherever I want to tie things together with a clean appearance. AN hoses, power, harnesses, etc.
The cord is waxed nylon that when tied properly is as strong or stronger than zip ties with neater more dressed appearance and don't shrink or break like zip ties can. Also, no sharp corners!
If I'm working on something a bit more focused....like bundleing cords, I'll grab the small electroncic cutter. Always gives me a nice flush cut on zip ties.
More often than not, I'll just grab whatever diag I have at hand and just attempt to cut it flush. It's a give or take on whehter I leave a sharp edge if I'm not paying attention to how I place the plier on the zip tie.
Disclaimer....I have the fancy schamncy $400 specialty tie gun somewhere in my stash, but it's just too bulky for my use.
I'd be curious if you guys have some special cable tie tool cutter I'm not aware of....
I've switched over to using Velcro instead of cable ties. I have to go in and do rework to often to use cable ties. And I only use Velcro if I can't find a way of eliminating the cable run or keeping it short enough not to need to be secured.
When I did use cable ties I either used one of the guns or small flush cut wire cutters. Hated getting cut up on the sharp edges. I would rather seem them left untrimmed than to be cut leaving a sharp edge.
Me too. Just walked over to the belt sander with an older pair of side cuts and hit until I had a straight back side. Works great.I made my own flush dykes all I did was grind the back side.
