Converting a old mig to a stick welder?
taumac
Brooksville, Fl
I got a old CEM dual mig 140 220v welder. After many years its finally died, well its the plastic gears in reduction drive system which is shot. I plan on getting a Lincoln pro mig 140 in few months im wondering if it possible to turn this into a dc stick welder? I know that arc is trigger controlled how can I bypass it to work it like a stick?
rsanter
visalia ca
You may be better trying to convert it to a TIG
Negative lead stays the same
Connect TIG lead to the positive lug
Make a simple foot pedal,that will just do on and off
Bob
zkling
Completely different power supply. Mig is a constat voltage process, stick and tig is a constant current process. Hence you see most tig welders double as a stick welder. To save time typing, give this a read through. Used basic transformer stick welders are usually pretty cheap, easy to find and dang near impossible to kill.
http://www.lincolnelectric.com/en-u...stant-current-vs-constant-coltage-output.aspx
gmwelder86
Oakdale , ca
Exactly right. Comely different powering process until you get into inverter multiprocess machines.
T
taumac
Brooksville, Fl
Read up.... So wonder what then I can use this for? I'm buying a new mig soon and new drive I see is $80 $100 and don't see dropping money into this one. Any suggestions?
Rookie2
Western Pa.
IF you have the leads , easy to wire up and try.
Hell if I can mig weld with a couple of car batteries or stick weld with them , you can stick weld with your mig.
rsanter
visalia ca
Very interesting, learn something new every day
As for,your machine, how about you give it to,someone whom wants to get a start with some hobby welding with the understanding of what they have to buy
Bob
T
taumac
Brooksville, Fl
Bob
Thanks, After thinking about it I think I'm gonna do just that. I have a friend of friend who just loss everything due to a divorce and and think between them they can find parts here or there to get it up and working. I mean find they could find cheap 110 mig somewhere and use drive and gun off it and its working again. Its just not worth me putting money into it.
zkling
Is it just the gears that drive the rolls that are shot? Can you post a picture that shows what exactly the problem is? You may be able to find parts for it via another brand. Lots of the off brand small wirefeed units share common parts.
Lhorn
If you end up considering scrap, please let me know. I'll give you a few bucks for gun. I got an old MAC welder dirt cheap on CL but the gun is pretty beat and I don't want to put alot of money into getting a new gun.
can you add a spool gun to it? then you could use it for aluminum.../QUOTE]
Correct me if I"m wrong, but you would need a spool gun and a HF box. I'm not aware that anyone makes these inexpensively so those two items alone (used) would cost 2-3 times what that welder cost brand new.
T
taumac
Brooksville, Fl
I can post pics later when get home.
Have a good one, Gerard
The 5 Stitches Garage part 1 http://www.garagejournal.com/forum/showthread.php?t=142100
The 5 Stitches Garage part2 http://www.garagejournal.com/forum/showthread.php?t=211899
T
taumac
Brooksville, Fl
The gun is pretty beat up too and can't find replacement nozzle but later will post pics of all the issues with it.
T
taumac
Brooksville, Fl
Ok got pictures
1 welder I have
2 drive system
3 square drive which drive roll goes..... Lots of play in it even through pic 1 triangle holds it in place
4 gears all plastic
5 teeth worn on smaller sprocket
This is old welder I had for about 7 yrs and its previous life I don't know to tell. I know its a HF welder or was offered at HF. I can't find parts but I do find them in the UK. Apparently, these are used a lot over there cause did search and eBay came up with parts and seems like all all in the UK. I looked up replacement guns as well as all parts I need and seems it would be easier to buy a 110v HF unit for $100 and steal gun, ground and drive system for this one. I modified the leads also from 4 to 10 ft and new liner and I removed gas line cause couldnt find a nozzle. All that said welder welds good and never gave a issue except driving wire.
uploadfromtaptalk1390351022660.jpguploadfromtaptalk1390351037010.jpguploadfromtaptalk1390351051859.jpguploadfromtaptalk1390351065369.jpguploadfromtaptalk1390351080018.jpg
sberry
Brethren, Michigan
I am all for salvage and understand hobby but this isn't worth the effort, not just my opinion but from thousands of others that faced this, give away for parts to an enemy, let him suffer the frustration and easily replaced new for less than the repair.
