Phaedrus29
- Joined
- Jan 14, 2014
- Messages
- 16
I've recently discovered this forum and I'm finding all the information very helpful. I'd like to fit a 4-post lift in my garage but I have some obstacles in the garage which are making this tricky. Here are a couple overall pics of the garage (please excuse the mess):
<a href="http://imgur.com/DUJS68k"><img src="http://i.imgur.com/DUJS68k.jpg" title="Hosted by imgur.com"/></a>
<a href="http://imgur.com/fwL98xA"><img src="http://i.imgur.com/fwL98xA.jpg" title="Hosted by imgur.com"/></a>
One obstacle is this damn ceiling beam going across the middle of the garage:
<a href="http://imgur.com/vRF1ZTj"><img src="http://i.imgur.com/vRF1ZTj.jpg" title="Hosted by imgur.com"/></a>
The height of the ceiling is 10'7", but the distance from the floor to the beam is only 9'. The garage is pretty deep...there is about 12'10" (154") from the garage doors to the beam. Then there is 8'6" (102") from the back edge of the beam to a damn cement raised platform at the back of the garage (which you can see in the first pic). The cement platform is 4'4" (52") deep. Here is a pic of that platform that leads down to an egress:
<a href="http://imgur.com/TVosT5w"><img src="http://i.imgur.com/TVosT5w.jpg" title="Hosted by imgur.com"/></a>
That cement platform is another tricky obstacle...I think if it wasn't there I would be able to fit the lift behind the beam and wouldn't even have to worry about garage door clearance...that raised step area is very wide.
The car I would like to fit under the lift is a Subaru BRZ that is 51" high. On top is a 1968 Mustang (convertible) that is 52" high.
Is this doable? At this point I'm seeing two different "options". Both options would require part of the Mustang (hood or trunk) extending under that beam. The Mustang length is 181" or so. The Mustang from windshield to rear, for example, is 116" in length. So if the lift was right inside the garage, I think the Mustang could fit with the hood extending under the beam...the hood is only about 34" tall.
So Option (1) would be to put the lift right inside the garage door. This would require switching to a high lift track on the garage door. One worry I have about this: Even with a high lift track, wouldn't the garage door still lower the clearance somewhat from the 10'7" ceiling? Can it still work?
I'm not even sure if this Option (2) is feasible: If that cement step can be removed and the floor leveled out, then I would have 154" behind the beam...I could then put the lift past the beam at the back of the garage (and the Mustang would again have to extend a bit under the beam). I'd have the full ceiling clearance without even worrying about the garage doors. Can this even be done, with the slab remaining secure for the lift? Is it a much bigger job such that I should just go with option (1)?
Well sorry for the long first post but I could really use some advice here since I'm pretty confused, but also excited about the possibility of a lift. Thanks for the help! Here's a pic of the garage from the outside:
<a href="http://imgur.com/qYgYm3d"><img src="http://i.imgur.com/qYgYm3d.jpg" title="Hosted by imgur.com"/></a>
Thanks again for any thoughts.
