240V heater my garage?
littleman66
Canada
will a 240V heater heat my garage well?
how long would it take too heat up my garage to temperature i can comfortbley work in with a sweater on?
its a brand new 24x24"
2x6 walls with R20
two R 16 garage doors
triple argongas windows
L
littleman66
Canada
O sorry i live in Canada.
its been sticking around the -30C(-22F) outside, -48C+(-54F) with the windshield
timgr
Medford, MA USA
Electric heat will heat just as well as natural gas, oil, propane, wood, or whatever. As long as you buy a big enough heater to do the job, and can afford the electricity, an electric heater will be fine. In most locales, gas or oil is cheaper per unit of heat, so electricity is chosen as a primary heat source less often. Electric heaters are inexpensive though, and providing electricity is often easier and cheaper than plumbing gas. And electricity needs no venting, which reduces the installation cost and can increase safety.
L
littleman66
Canada
makes sense.
my plumbers are in the house as we speak. maybe i should get them too put in a gas line to the garage. i might use it some time.
maybe ill see how expensive the electrical bill can get before i install a furnace
by the way, you should post some pictures of your Jeeps.
im 20 now and iv had 4 already. looking for a minty CJ-7... hard to find something like that where i live
Tech Guy
Ontario Canada
We get temps down to -30 C as well. I have a double car garage fully insulated. I use the 240v heater from home depot or rona i think it was. Just over $100 bucks. I can work in shorts on low. 240 v 30 amp i think. Square red or orange box.
mulepackin
Montana
Personally, I'd hate to lose that wattage that could be going to a piece of shop equipment; welder, table saw, dust collector, air compressor, etc. Thats one of the reasons I went with gas.
PoorOwner
CA
I have one of those heater it will work well in a 2 car garage that is insulated.
It takes about 15 minutes to feel a difference in temperature.. then it's as hot as you like (depending on the outside) and as fast as your meter can spin :O
It depends on your needs, if you don't want to deal with gas and venting requirements then this is the way to go, but cost to operate is more.. most house hold use more electricity than gas already.
Tech Guy
Ontario Canada
Like Poorowner said, I fire it up 15 min before I go out there , warm as anything then turn it off when I am done. Its also on a cord so I can move it around to any area
BirdRacer
Does it look like one of these?
Tech Guy
Ontario Canada
Just like the yellow one. Yes it draws 30 amps when running but I have a 100 amp service in the garage so still have lots of power. Those little heaters work great
