Spray can storage rack
ilya
Santa Monica, CA
I'm looking to add a spray can storage rack to my service cart / work bench. I found this product on Griot's garage:
http://www.griotsgarage.com/product...utions/liners+&+racks/metal+spray+can+rack.do
35750
The design of this rack seems to be quite simple, but unfortunately I neither have a sheet metal brake nor a scroll saw. I was wondering if anyone can recommend a simpler DIY design for a can rack that doesn't require any power tools apart from a power drill.
Brad54
I copied it.
If you have a drill, a vise and two pieces of angle iron, you can make it yourself with a sheet of Home Depot metal.
Lay out the bottom, the side (upright), the top with the holes, and rather than a flange that goes flat against the wall, make a short down-standing flange that goes over the side of the tool box (just like the add-on cabinets that hang on the tool box).
Drill the holes with a hole saw.
Mark the bend lines.
Put two pieces of angle iron in the vise, close the vise, and make the bends.
Paint it red, and away you go.
The HD metal was a little thin, so I took a small strip and made little ties going from top piece to bottom piece, and pop-riveted them in, so the bottom of the rack wouldn't sag with the weight of the cans.
I also drilled a hole just slightly undersize for a piece of 1/2-inch hard metal fuel line (next to the can hole on the end), and use it for the little red straws.
If someone can post a pic for me, I'll shoot one tomorrow.
-Brad
I
ilya
Santa Monica, CA
Brad,
Your approach sounds exactly like what I had in mind! I'll have to get some angle iron stock, but I do have a bench vise and a drill.
russlaferrera
Central Virginia
This came to me just now. Use an aluminum house gutter. You cut the gutter the length you need. Then cut the bottom making a "L" with a retractable knife. You will need 2 pieces to make 1. This will make a "U" shape. You now have to male end caps. Make them out of wood or pop rivet extra gutter material.
House gutter is cheap, this is easy to do, and it's pre painted white or brown.
sctattooer
Myrtle Beach, SC
I went to Home Depot, closet storage dept., and bought 2 of the vinyl shoe racks that hang on the wall. 9 bucks, works awesome, and looks cool too. The clear vinyl lets you see the labels, and fits the spray cans perfectly. If you dont need space for 24 cans, simply snip it down with scissors.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
35750
Go to WallyWorld and they have basically the same thing in the automotive section. I can't remember the brand name, but they are either black or dark gray, and along with that, they also sell other garage storage items along with panels of metal pegboard. At our Wally it was in the same aisle as the Rustoleum garage floor epoxy.
Bob Paulin
N.E. USA - Atlantic Canada
FWIW....
I buy several cans of name-brand spray paint (Krylon, Dupli-Color, etc.) when it becomes available for 99 cents-per-can at my nearby liquidation/salvage store.
It used to be that if the cans stayed around too long before use, the nozzles would clog - no matter how much I shook the cans.
I figured out that the solids and sediment went to the bottom of the can surrounding the tube, came up the tube, and clogged the nozzle.
I now store all my rattle can paints on their sides so the solids gather on the side - not at the tip of the tube.
I have also copied an idea I saw somewhere and built a rattle can shaker out of an old $5.00 saber saw I found at a garage sale.
MOPARHOUND!
Kansas City
FWIW....
Great tip on storing spray cans on their sides.
I'll have to toy around with the saber saw idea. Got a pic?
Another trick I learned on one of the Dodge boards, is to set the can in a bucket of hot (not boiling, of course :)) tap water prior to use for about 10 minutes. The paint flows much better. :thumbup:
Brad54
FWIW....
Taking that a step further: get yourself a plastic milk crate, set it on its side on a shelf, and stack the spray cans in it. One of my favorite garage tips.
The sediment settles along the entire length of the can so it's quicker and easier to mix. It's also very, very much easier to find the color you're looking for, as it's usually on the top of the can.
I only keep WD40, brake clean, Eastwood's PRE cleaner, spray lithium, etc. in my can rack.
-Brad
JB740i
Central Florida
I made one out of a half sheet of 3/4" plywood and screwed it to the wall. Had 4 shelves or so.
Copied someone elses design on here.
sirswank
the littlest state
my rack used to be the inside of an old refrigerator door i had screwed to the wall.
this time around i will adopt the "store on their side" method.
jniolon
hueytown, al
you guys don't have enough cans !
I went out and counted just rattle can paint cans... I've got 64. I use a standard double door office supply cabinet 36" wide 18" deep and 7' high.. just the paint takes up two shelves.. oil and filters below on another.. grease and misc on one lower.. antifreeze and large containers on the bottom.. I don't have the wall space for something like that
john
goodfellow
NoVA
john
Yup, I just counted my cans. I figured I had 20-30 or so. Man was I wrong -- 53 paint cans. I like the idea of sideways storage -- makes a lot of sense. I'm going for the milk crate route this afternoon.
Stuart in MN
Minneapolis
I did a big garage cleanup last summer, and I think I tossed about 53 spray cans that were either empty or clogged up. :) There's still plenty of good ones still out there.
I tend to store them on their side as well, but I just stick them in an appropriately sized cardboard box sitting on a shelf.
e-tek
Saskatoon, SK
I went out and counted just rattle can paint cans... I've got 64. I use a standard double door office supply cabinet 36" wide 18" deep and 7' high.. just the paint takes up two shelves.. I don't have the wall space for something like that
I have the same set-up - but I'm gonna staack them on their sides in the same cupboard! Can't believe this wasn't common practice/knowledge 'til now!!
Funny - I almost wrote this word for word before I saw your post!
I also finished my spray can shaker that I started a thread about - I'll post pics soon! (made from a WS wiper motor).
