Can I cut granite slab with a regular cold chisel?
pendragon1998
NE Georgia
I have a small piece (~6x10) of 1 inch thick granite countertop slab that is roughly trapezoidal in shape. I would like to square off the ends so I can mount it in a box. Can I use a regular cold chisel from sears to do that, or will I destroy the chisel? It doesn't have to be a pretty edge, just approximately square.
janbuick
netherlands
I think when you use a cold chisel it will cack the wrong way
perhaps you can borrow a grinder from a neighbor
jan
A_Pmech
IL
Circular saw with a diamond blade would be my choice, unless you have a powerful tile saw.
The problem with using a chisel is the chance of breaking the granite in a direction you don't want to go. :)
shoot summ
Don't own an angle grinder, nearest HF is 1 hr away, the slab was free, and I already own several cold chisels. :)
HF has online sales, really cool, they deliver right to your house.. :)
The quality of the "cut" you might get from the cold chisel will depend on the granite. It might come out great, or it might crack the whole piece.
Do you have a circular saw? You might be able to find a diamond blade for it instead of getting an angle grinder.
An angle grinder is on the list of tools that everyone should own.
wrenchguy
NW Indiana
+1, if u've rented a concrete saw in the past u had to get a diamond blade. u get stuck with it when u return the saw. take the blade and put it in ur 12" miter saw and make ur cut slowly. works good, been there.
Westly
U.S.A.
The chisel will just crack it and there's no predicting which way the crack wlll run.
Autorotica
SE Pa
Id give it a try on a small corner, not end to end square at first.
I would use an air chisel (cold chisel could work too) and score the line on both sides of the granite and keep going with it until you have the break path pretty well defined.
Clamp it in a vise and see if you can snap it off like "cutting" glass.
Safety glasses, safety glasses and did I mention safety glasses?
Good
rsanter
visalia ca
You cannot take a big chunk off
You can do what is called a chiseled edge where you tale a little off the edge at a time
This is generally done in the industry to give a rough natural looking edge and for art type stuff.
In your case you can keep doing it till you have it down to the shape you want.
It will not be straight but wavy. How wavy will be based on how good you are and how good you get
Bob
P
pendragon1998
NE Georgia
I'm not sure which is worse, not owning one, or admitting on GJ that you don't own one... :)
Hey, take pity on me. I'm in the market for a lot of tools (angle grinder included)... just don't have the money to buy 'em all at once. I missed those great prices on the angle grinders at Tractor Supply last year or I'd have picked up one then.
shoot summ
Just messing with you man, it takes time to build the tool arsenal...
