The W I D E Choice
HAP
NE North Carolina
Anyone considering putting one of these on a 2 post lift will want to opt for the wide configuration for sure. With a wheel stance 1" wider than a H1 Hummer I am glad I did.
R,
HAP
zkdiesel
chicagoland cornfields
Still narrow compared to my 18k rotary that I can drive a semi with mirrors nt folded in through
Yes, wide is only way to setup a lift as long as it doesn't hurt your space
H
HAP
NE North Carolina
What model is that? What is your max width between columns?
I have the Bendpak XPR 10. In the wide configuration, there is roughly 107" between the carriages. The Raptors wheel stance is 87". This measurement is more important in some cases.
MN4x4
Minnesnowta
Hap, how wide is that truck? It doesn't look as wide as an H1 but it might just be the picture angle.
rburke65
Canfield, Ohio
Is that a "chain bucket" on the top of the left post. And for what, do you use the level that is there on the right post? Nice set up?!
H
HAP
NE North Carolina
MN4X4: see post #8. Notice OEM marker lights.
GRN: The boat is a 26' Scarab "Sprint".
rburke: Yep, hoist chain bucket. As for the level, it was just a handy place to store it (magnetic base)
R,
HAP
MN4x4
Minnesnowta
With a wheel stance 1" wider than a H1 Hummer ...
Actually just read the specs on the Raptor and it looks like the stance could be 2" wider than the H1. How hard is it to find a parking spec that will accommodate it?
evildky
Louisville, KY
Wow I had to look that up, the Track width of the Raptor is in fact 1" wider, the vehicle width is almost exactly the same and the H1 is about 4' wider with the the mirrors out. Big truck. I thought my tundra was big but it's 7' narrower with 4" less track width.
