TheShrine
Is there any benefit to daisy chaining 2, 20 gallon 175 psi air compressors? If so...is there a right and a wrong way.
Thanks..DJ
Thanks..DJ
We use alternators on duplex units and staggered operator settings on separate units feeding the same manifold, so you have a "primary/secondary" setup. One runs for the majority of the time, the second (sometimes a little smaller) unit comes on if there's a failure of the primary or if the demand is high enough that the primary can't satisfy the demand.
Tommy
What kind of pumps are we talking about? There are a few ways to do it, you really don't want to just hook then together and go otherwise they will fight each other and their respective pressure switches. Personally unless you have some quality pumps I'd be inclined to sell both and put that money towards a good 60gal vertical unit.
Realistically, if your two 20 gallon compressors are each only 2-5 cfm its a waste of time, effort, and space. If your two compressors output at least 8+ cfm each then its probably worth it.
Whether this is a good idea or not has NOTHING to do with the output of the compressors and EVERYTHING To do with the needed output.
It is very easy to connect two...or ten air compressors in parallel. (You can't connect them in series)
In my shop, I have four 120v compressors plumbed together. That's around 8hp output, more than one nice big one. They all run at a different pressure. I keep them in their own room so I can't hear them either...
The comps don't care what the switches are set at, for the most air set them to run at the same time. Only reason I have mine set different is I want one to run as the primary, my second is a relic, only used as needed.
and I possess two 2 gal comps. Upgrading is always good but not now. .
Thanks..DJ
You have two different sets of information here, What do you really have?
lg
no neat sig line
My bad.....2 different 20 gallon comps. 1 single, 1dual. I think a manifold parallel set up w up/down pressure switch sequencing is the way to go but pics work for me. I'm in a wheelchair most of the time so I have to be creative. Not a lot of chances to get it wrong or redo.
You guys are "walking" me through the mistakes I would have made on my on. Me, my wheelchair/walker and 2 compressors will be a tight fit in my compressor room.
Thanks again!
The one thing to be careful of here is that both compressor tanks are rated for the highest pressure.They will not fight each other.
170 cutoff= 150 psi in the line and one runs
Plus
120 cutoff= 100 psi in the line and both run.
Lower pressure unit CANNOT kick in when pressure is higher.
To those who said differently; convince me.
This his how you plumb them in parallel. To plumb them in series would require you to modify the compressor and feed it air that is already compressed. (That's a 2 stage compressor)Connecting them in series is very possible and easy to do, you just plumb lines between tanks, keeping a single output from one to the shop air manifold.
The air pressure switch isn't the only part. Let's say for example you have a 120PSI compressor and a 150PSI compressor. You can't simply plumb them in parallel and call it good. When you put 150 PSI into the 120 PSI compressor, you will pop it's blow off valve, and most likely, the first tank isn't rated for as much pressure as the other one.If youre running multiple compressors you also dont necessarily need to adjust the pressure switches or regulators regardless of the plumbing, they wont "fight" each other, each cuts off when it reaches its individual limit.
This is about using what you have. Do you think I just woke up one day and said "I want four 120v compressors all stuck together!"? Just like the OP I decided it would make a whole lot more sense to plumb together what I have than to go buy another bigger compressor.JME, but there is such a tiny difference in used price between the tiny "portable" compressors and decent smaller stationary industrial 8-10 cfm ones that the first just isnt worth the effort bc the second gives a much higher duty cycle and life span, half the noise, and saves room.
Check valves on the storage cylinder output lines upstream of the manifold eliminate having to use multiple regs & changing relief valves (which is also NOT a good idea unless you swap the higher rated one out to the same rating as the lower one. NEVER increase the rating of the relief valve).
Tommy
This is the way to do it. You should already have a check valve before the tank but you'll need another on the output of each.Check valves on the storage cylinder output lines upstream of the manifold eliminate having to use multiple regs & changing relief valves (which is also NOT a good idea unless you swap the higher rated one out to the same rating as the lower one. NEVER increase the rating of the relief valve).
Tommy
Let me ask a couple questions here, How do you know that the relief valve on a receiver tank is the proper one? If your receiver has no relief valve, how would select the proper one?
Well....thanks to all contributors. I have a one time project and will be using a table top blasting cabinet. A lot of good ideas here but my needs are temporary and I possess two 2 gal comps. Upgrading is always good but not now. I have 2 garages and each have a comp. My needs are for simplicity and temporary.
Any pics of a parallel set? I'll work through the pressure switch timing.
I may have missed it told somewhere, but I am assuming these are both 120v compressors.
If you want something quick and simple just make a manifold like the one in my picture, except make it with 2 male quick release fittings instead of just 1. Use short hoses and plug the outputs of your 2 compressors into both of the male fittings. Run your tool hose out of one of the female quick releases and you should be good to go. Set both your compressor output regulators at roughly the same pressure (the ideal pressure for the operation you want to perform). Changing the cut-in and cut out pressures of the compressors will most likely achieve nothing for a short term setup like this, because the likelihood of them both kicking in and out at the exact same instant is pretty slim. Just make sure to plug them into different garage circuits and it shouldn't matter. If you are really nervous, plug them into circuits that are on opposite phases from each other at the panel which would then ensure no tripping of the main, because the inrush currents would not add to each other even if both start at exactly the same time.
