I pulled into the garage last night and the garage door opener lights did not come on. In the darkness I noticed that the heat exchanger tubing on my big maxx heater was glowing red hot while in operation. I never would have noticed it with the lights on. They glow red at the point where they make there first bend and go back into the heater. Is this normal for the unit? The fan is working and the flames seem centered in the tubing and are blue in color. The only thing I can think of is that the manifold pressure may be off. The altitude here is a 3500ft. The data plate on the unit says 4.0 inches for 0-2000ft and 4.0 inches for 2000-4500ft and to adjust only if you go above 4500 ft. The instruction manual with the unit contradicts this however and states that 0-2000ft =4.0inches 2000-4500 =3.6inches. Perhaps I should lower the manifold pressure. Has anyone else noticed this red glow when the garage is dark? Is it normal? If not what did you do to fix it?????
