1940_dodge
Has anyone done any systems like this? Tried searching the forums and didn't see too much about it. I have average wind speeds where I am of at least 20mph, and sunlight a good chunk of the year has direct sunlight.
Plenty of topics about that in the electrical section of the forum.
Where are you?
For the wind, the larger the unit you get the more wind you need to make it generate.
If you have average wind speeds below about 10 you are going to have a hard time getting it to pencil out.
For solar if you have good sun that can work for you. You can do DIY and by the panels for about $1 per watt and then buy the inverter you need.
Total install if you do it yourself should be about $3 per watt and if you hire it out you should be able to do about $5 a wall or a little less.
Bob
Dodge,
Lots of requirement and restrictions. If you put up a tall unit for wind power, you have to have 1.5 X the height as a clear fall zone. Here is some information on solar power systems...
http://www.ecobusinesslinks.com/surveys/solar-power-kits-price-survey/
Chris
I haven't seen anything on the topic of wind power utilization, and even the solar is really light as far as information for just starting out.
What about just having a smaller unit for emergency power/LED lighting?
I'll make it simple.
You will have an outlay of funds that takes many many years to recoup, if ever.
We have a camp of folks who think a ten year period to get your investment returned, and then another ten to double your money is a fine thing.
We have a camp that believes it is silly, trendy, and of no value as an investment.
This forum really isn't a good place to ask about such.
As emergency backup...it just isn't. Both sides agree on that.
For wind to work it needs to be high....normal terrain really cuts down the wind speed....i.e., the closer to the ground you get, the less wind you have.
Solar is more DIY doable...
