Legacy Flooring 2 years later
mnluke
So I was lying on my garage floor today doing an oil change, Of course I spill a bunch of oil, but it wipes right up considering I have an epoxy floor. I just realized I coated my floor with Legacy Industrials HD coating about 2 years ago and never put up a review.
Well I couldn't be happier, this floor has been absolutely used and abused, I weld on it, grind on it, have set the grinder down while the wheel is still spinning, lots of oil, trans, diff fluid changes. The wife is the worst as she like to do 100 point turns backing out of the garage with hot tires on 100 degree days. The floor doesn't look new, but I am sure if I actually took the time to mop it up it would.
I used their 600sqft garage kit, with a urethane clear coat, I filled the expansion joints with the flexible gel sealant.
Floor was cleaned well and acid etched.
Holding up great! :thumbup:
Lucas
mnluke
Yeah sorry should have put up pics....
As you can see I need to work on my flake spreading technique...
mnluke
Did you do epoxy coat? How has it held up to welding?
It has left a few marks from welding but those marks were from welding on the actual floor. Not smart to do.
Welding on a table above the floor or on a vehicle, no issues.
