Brake Line Clamp
The Critic
CA
I'm looking for a special clamp that is used to clamp off brake lines so that the fluid will not spill out when I have the brake caliper removed.
I heard that there are special clamps that you can buy that will not damage the brake line when you clamp it.
What do you folks recommend?
Thanks.
Blacknwhitepit
Eastern Tennessee
http://www.kd-tools.com/3438.htm
or
http://www.sears.com/shc/s/p_10153_12605_00994288000P?vName=Tools
sjdiscounttools_2033_335916332
-BWP
Fedwrench
Valley of the sun
We're talking about clamping the rubber flexhose that runs from the caliper to the steel brake line?
I use a small pair of needle nose vise grips with rubber hose over both jaws to keep the teeth from cutting into the hose with light pressure. I would recommend the yellow plastic clamps pictured in the link above. You would be less likely to damage the brake hose internally by over clamping it with a metal tool. The plastic ones work great. You just don't want to deform the hose and cause brake drag problems later.
If you're replacing the calipers, I would replace the hoses too.
nissan_crawler
Wichita, KS
problem is, those hoses aren't always just rubber. Go ahead and throw a clamp on a teflon line, I bet it won't be pretty.
I just throw a rubber plug on or in the line.
krusty the clown
Member Emeritus
niangua, mo
i'm not as concern with weak spots as i am damaging the lining of the hose and causing the brake to stay applied..........i have replaced too many hoses for dragging brakes to cause one.
nissan_crawler
Wichita, KS
Good point, I haven't had to deal with that, since I only work on my own junk, usually. I had poor brake pressure in my old nissan, though. I finally put two and two together, and remembered I had a shock mount fail offroad that I had to repair a month or so before that.
I undid that shock again, flexed the pickup, sure enough, the brake hose shrunk to about 2/3 of it's diameter. OOPS. I had stretched it to the point it just swelled up with brake application.
volvo
PNW 45th Parallel
i NEVER clamp a brake line.........
Like holding your finger on top of a straw full of fluid.. Use your adjustable hood prop and depress the brake pedal, then do your work and tighten up all fittings and hoses , then bleed. This will give you none to very little drip-age after the pressure bleeds off and keeps air from entering the system...quick/fast/ easy and you won't let the whole system drain out making a large mess and saves time and fluid on re-bleeding.....H
rsanter
visalia ca
+1 .. I would never clamp a brake line; heater hoses and even radiator hoses are ok, but not brake lines ..
I would be afraid to clamp brakehoses and I would be afraid to use a brake hose that someone has clamped
if you still want a set then have you looked at these
http://www.sears.com/shc/s/p_10153_12605_00947051000P
they are made by SK
I can assure you that the all plastic version will not get the job done. I have both sets and the plastic ones will flex too much
bob
T56 Impala
Roswell GA
I use a cap on the end. Most parts store sell a variety pack of vacuum plus. I keep a box of them around for just such a thing.
FWIW, I no longer have rubber hoses on my cars. One of the first things I do when I do brakes is swap them for braided stainless lines. It will give a much better and firmer feel.
Frank Elson
Lancashire, UK
All my lot changed to braided long ago - most of us run a lift anyway and need custom made longer hoses - so it's no clamps for us.
lametec
I use a set of these:
Motormite item 13889, BRAKE HOSE PLUGS.
They're not perfect as they still leak a little bit, but as long as you don't leave it for hours it's fine. I only bought them 'cause I needed to pad my order to get free shipping. They're $2.50 for a set of 4. I got mine from Autozone. They list it as 13888 and only show a single plug, but it's a set of 4.
r6_cannibal
Southern California
+1
first thing i do when working on the brake system for a new car is steel braided lines and super blue fluid.
I have a slew of rubber plugs accumulated over time i use for brakes, though i did use silly putty once in a pinch :bounce:
rhandwor
I use the Lisle tool and I never had a problem. It does speed up bleeding when done. Just be careful and watch what your doing. If the hose looks bad replace.
T
The Critic
CA
Thanks guys.
I like the yellow pliers that blacknwhitepit posted, I think I"ll get some of those. But I'll also get some of the plugs as well. You guys are the best. :thumbup:
Mr_fixit
Rustylvania
Me either.
I just depress the brake pedal a little, force a block of wood or something between the seat & pedal. that will keep the fluid from leaking. But in your case, a small amount of fluid willl be lost, since you need to relieve the pressure from the caliper. I thought this was a common practice.. I guess not.. I'd never clamp a rubber brake line..
johnny1290
Chino
FWIW I've used those plastic pliers and thrown them straight away, a brakeline laughs at them.
