Potential layout for new garage, what do you think?
Makoto
Houston, Tx
I'm thinkin of doing the corner closet like this with the workbench in the free space. that will keep my front free for stuff like hoists and other things on wheels.
Thoughts?
https://scontent-a-dfw.**.fbcdn.net/hphotos-frc3/t1/1901363_753722227972995_521212792_n.jpg
the black and yellow things are the approximate locations for the max jax (yes, i've already let the wifey know :) )
https://scontent-b-dfw.**.fbcdn.net/hphotos-ash3/l/t31/1654627_753722221306329_709983013_o.jpg
another closet angle (its like 4x4x8)
https://scontent-b-dfw.**.fbcdn.net/hphotos-prn2/t1/1896759_753722207972997_2046676421_n.jpg
thoughts feedback and comments are appreciated. thanks!
larry_g
oregon
Looks good to me assuming that is a 30x30' building. If it is a 24x24' then not recommended.
lg
no neat sig line
nolimits76
Oklahoma
I don't have a closet, but I have a door leading to the outside in about the same position. The thing I don't like is that you lose valuable wall space at the front for the door swing. So in essence, you lose the 4' for the closet + whatever size door you go with (another 24" or 30" probably).
Have you considered something like this instead? Gives you the corner storage, and allows you to **** work benches all the way up to the walls.
Makoto
Houston, Tx
I've thought about that. here it is drawn up
https://scontent-a-lax.**.fbcdn.net/hphotos-prn1/t31/1965528_753847927960425_1703697747_o.jpg
its a 27x22x8 BTW with a 18 or 20 foot door (we close on the house in 7 days!)
zkling
Personally I'd ditch the closet idea.
nolimits, you have a VERY nice garage.
Carl B
Clearwater, Florida USA
I'd get a couple metal storage cabinets. 18'' deep, 4' wide - on castors. They would give you more useful shelf space. Then maybe some package racking if you need to store larger items. If I built a closet - it would be to hold a compressor and keep the noise down - but then I'd put that on an outside wall.
if you need more storage - design the Trusses and Roof to provide that as well.
just my thoughts,
Carl B.
grommit
"Personally I'd ditch the closet idea. " X2
This would be a good area for a vertical air compressor and waste oil storage.
Windows for ventilation ?
nolimits76
Oklahoma
LOL, thanks man, but that isn't my garage. It's someone's kitchen. I just found a picture on the internet. Although our kitchen is similar, and we have the same shape of pantry. We love it. It makes good use of an awkward space and gives lots of storage.
just my thoughts,
Carl B.
Since he's closing in a week, I doubt truss and roof design are options at this point. However, I do agree that having a useable attic is a must. I have a good sized space above mine and just moved a bunch of junk up there. It's made a big difference in helping me get things organized.
If by the chance the OP is building, make sure you get all the lights you want installed before you move in and make sure the builder insulates over the attic. Also, I would have them deck the attic with 3/4" plywood. And while doing all that, you can get larger and more heavy duty pull down ladders. The narrow 225# builder grade **** they put in is a joke.
It also crossed my mind about putting a compressor in the closet. It would help with noise levels. Theoretically he could do another closet on the other side to house the compressor. If doing this, make sure it still has enough room so it doesn't overheat, and there is a way to vent it.
Lastly, I'm not sure I agree with your statement about the metal shelves providing more storage. I don't think it's a bad solution mind you, just I think sometimes you work with what you have and can do. Some of the shelving units are expensive, but have the advantage of going with you to the next house.
Here is a screen capture from my AutoCAD software. I drew up with your 4' x 4' dimensions. I made each wall 25" so that you would have room for 24" wide work benches. That leaves you 32.5" on the front face, which allows for a 24" wide door w/ trim to fit.
I drew it up because I wasn't sure if the one side was wide enough for a work bench. In your 3D model, it looks like one is but the other looks tiny. It could just be a visual effect of the angle we are viewing.
Makoto
Houston, Tx
thanks for all the info guys! The house was built in 1980 and this is a detached garage. It has exposed studs and wiring. I'll be sheetrocking it and flooring the attic for more space up there. The idea behind the closet is to keep things like fluids, paint cans, shop vac, and other oddball things out of sight but easily accessible.
The idea is i know I want to keep things out of sight so why not just make a decent little closet for that stuff?
Here's my current closet so you can see how i've got it packed with lots of odds and ends type things.
I haven't quite figured out where but I'm going to put a good attic ladder in as well as a vent to the outside for hot air and fumes (I will be doing some painting every once in a while).
oxmanwi
Milwaukee, WI
You have a 8' ceiling? The maxjack will not clear that, you might want to look into making clearance up top, I'm in the same boat with a 8'6" ceiling. I'm begging the wife for a max jack.
Makoto
Houston, Tx
from the maxjax website:
For a little more money, why not get a real lift?
Answer :
Out of all the questions we get, this one is the most befuddling to us. It's not like MaxJax is a bicycle and we're trying to call it a car. The MaxJax is a true lift, capable of safely lifting most consumer vehicles to a comfortable lifting height for service and maintenance. If you've got the room and you've got the cash, there is no reason to not get a huge two-post lift and have it installed in your garage. But don't forget, not everyone has a pole barn, four-car garage, or room to install a full-rise lift or space-demanding four-post. Many automotive enthusiasts live in the city or the suburbs and don't have ceilings higher than 8-feet. Others simply don't want or need a lift for vehicle storage and would rather keep the floor clear. We created the MaxJax to be a product for those DIY'ers whose love for cars is bigger than their workspace. Many car enthusiasts appreciate the unique benefits that only a MaxJax can deliver. It's a one-of-a-kind lift that replaces their floor jacks, stands and ramps, and allows them to safely perform general undercar work.
It seems like its marketed to us specifically.
Wingnut65
Tampa Bay, FL
Nice layout, but that closet... Is it just a storage closet???
The shelves in the closet are the actual storage space that you are planning. The floor space in front of the shelves and inside the door is just circulation space. It the door would not be there, that circulation space would actually be part of the garage space, instead of closed up closet space. Storage cabinets may be a better option to you.
Unless... Unless you plan to put your compressor in the closet and build it for acoustic control... At times, I'd really like to have my compressor behind a door so I don't have to use headphones.
Good luck with your project.
Makoto
Houston, Tx
Yeah its just a storage closet. I want to be able to hide away my ladder, vacuum cleaner, brooms, and other bulky stuff that doesn't quite fit in a standard shop cabinet.
Why do you guys think its a bad idea? I keep thinking I'm always going to want a broom closet. Just curious, I'm definitely not married to any ideas at this juncture.
Thanks for the feedback!
larry_g
oregon
My thinking is that your giving up near 4% of your garage space for a closet. Is it really worth the space for storing what you have listed? Your decision.
lg
no neat sig line
Makoto
Houston, Tx
That's a good way to put it. I think giving up that corner to keep ladders and other stuff (i'll always need a space for) out of sight is probably acceptable.
here is the maxjax simulated as lifting the car 4 feet in the air BTW
mebuildit
Scottsdale, Az.
Nice plans. I am also in the process of building a 50x50 shop. I found some really neat tall sliding door shelves at IKEA last weekend. That way you don't have to open up a door that can swing into something. I wish that I had taken some pictures of that but it was every bit of 7' tall. Might think about a pocket door is what I was leading up to.
