ScaldedDog
With apologies to the late Dr. **** Treadway, I'm vacillating on the precipice of indecision. I've read all there is to read on here, and am more confused than ever. My situation:
I'm about to light a 32x34 garage (915sf internal, after subtracting a 77sf utility room. Walls are 9'6", with a 12' peak at the ceiling in the front 20', and a 9'6" ceiling in the back. I'll have 13 8' fixtures: 4 running up/down along each side of the slanted ceiling, and two running front/back at the peak. 3 more fixtures will run front/back on the flat ceiling area, which will serve as my workshop. The lights will be divided up on three switches. Given this, T8's will deliver 1.8w/sf, and high output T12's will deliver 3.1w/sf in the same space.
Here's a decent photo of the space:
My questions:
1) T8 RFI - Is there anyone on here with >10 8' T8 fixtures who does *not* experience interference with their radios? RFI is a deal killer for the T8's.
2) "Best" light - Which of the two choices will deliver light that is most pleasing to the eye? I know this is a personal choice but tell me what your experience has been. BTW, I'm planning 4100k bulbs for the T8's, but haven't yet decided what ones to run if I choose T12's.
3) Experience - Have any of you had both of these? Which did you prefer?
4) Mixing - Any advantage of mixing the the two types of fixtures? Any down side to that?
5) Flicker - Which of these will flicker less? The only reason I ask is that the T12 fixture I saw in Lowe's the other day was flickering like crazy, and the T8 right beside it was not. Is that generally the case?
6) Source - I was planning on getting these at Lowes or Home Depot. Any particular fixtures to buy or avoid at those places, or another source you'd suggest?
Thanks,
Mark
My questions:
Thanks,
Mark
The T5's are awsome, but may not be economical due to high initial cost. You can get 4' T8 fixtures at the big box stores for about 9 to 10 bucks each.
