jakemac
I'll go $25!!!
I thought that the counter offer in a bidding war was supposed to include a jar of pickles. Isn't that the rule around here ?
I'll go $25!!!
http://westernmass.craigslist.org/tls/4348232501.html
Interesting $80 vise. Anyone know who the manufacturer is? I emailed out to the seller but no answer as of yet
Found this on craigslist for $25
Looks like the date made, says 11-22-44
Thats a great find Sleipnir! What's the writing on the main screw collar retainer say?
I need a vise Dr...... when I open the vise the screw comes out about 1" and then the jaws move out. It will close just fine. Every thing feels smooth when I open or close the vise.
Low Friction is correct. what you need to do is either turn the vise over and re tighten the loose sleeve (not sure technical term) by turning the little screw into the main screw or replace screw if it is now missing.
or pull out the dynamic jaw completely and turn it upside down and snug up the sleeve before tightening. here is a picture of my Prentiss vise of the part we are talking about. I would pull out the front dynamic jaw all the way if it was me.
good luck
If I recall correctly, when Emmett put a serial number on a patternmaker's vise it was usually on the top edge of the front jaw. If you don't find one there, your might predate serial numbering.
Sleipnir, it definitely has all the makings of a Charles Parker. I don't think I've ever seen one without some markings on it.
Does it have any pins in the areas I marked red?
Yeah two of the spots show a pin but the other two spots are kind of been scraped with something so it seems like it would had all four (top left/bottom right are showing).
The plate that he had underneath has 6 holes slotted I think for screws, by putting the vise on it then the nut at the bottom it seems to be really secure. He had it with the plate underneath mounted with 3 screws. Is this thing a really big washer or something? And is it a big deal either way? The reason I did it differently is that the washer type thing makes the vise sit flush since its got a hole that fits with a protrusion from the bottom of the vise. The whole drilled into the bench would need to be counter sinked and idk if I have a bit for that size and don't want to make the vise sit oddly (may wobble if I really work with it?)
edit: oh there's a stamp of some sort on the static jaw but it seems like too many layers of paint to read anything on it. only the size of a few numbers
?? Either way you have a really cool vise which you got for next to nothing. I'd give it a proper tear down and restore
.And for anyone looking for mounting ideas, here's how I did mine...
Started with a 1/4" plate of 7075-T651 aluminum...essentially it is used as a big washer:
Edges were bit rough though:
Sent the plate to Phoenix Specialty Coatings (forum member CudaChick1968 on here) to have it cleaned up and powder coated. She did a fantastic job cleaning up the edges and shot it with Wetstone Black wrinkle:
The vise base can be separated from the rest of the vise, making it easier to get everything in place and cinched down:
Picture of the through-bolts/nuts/washers from the bottom...had to do some careful measuring and drilling to clear the various obstructions that hide under the Lista cabinet tops, including the drawers:
I had to make a bit of a compromise on the mounting location...I could only get the static jaw to clear the bench on the front side. That's how it will be used the most, so I didn't mind:
Now let's see how long it takes to get some scratches in everything.
-- shop and workbench. I hope you enjoy many years of service out of it.
I believe you...
Photos never lie...![]()
