AST tools? and Subaru cam gear tools?
czgunner
WY
First off is AST still in business?
I haven't been able to access their web page in a while.
Secondly, I need some Subaru cam sprocket tools.
I'm an auto tech and we always do seals w/a timing belt job at my work (indy shop).
I have a few of the pin type for the metal sprockets, but I need the plastic hex type.
From my (confused) research, there are 3 different type?
If anybody can clear this up, I would appreciate it!
shockwave
Marietta,ga
Try company 23 they make a lot of Subaru only tools rallysportdirect sells a lot of there tools
And also I have good luck with sir tools cam lock on Subarus aswell
C
czgunner
WY
I saw the company 23 tools, but never heard of them.
Are they pro quality?
shockwave
Marietta,ga
I have used them quite a bit and work well but not as expensive as oe tools I know u can buy the oe tools from Subaru but not sure of website off the top of my head
woodstockva
USA
There are some new reviews for the company 23 products being done by Briansmobile1 on youtube. Here is the link to his channel -->
Here is the link to Company 23's website --> http://www.company23.com
I am sending the owner of Company 23 an email right now, so hopefully he will join GJ & reply to this thread. :)
Ft.ValloniaStreaker
Southern Indiana
I've done quite a few 2.5 DOHC and am trying to figure out how a special tool could help you. The pulleys have to come off to replace the seals anyway. Maybe I've just been lucky, or have a very strong grip.
Company23
Daniel, thanks for the invite!
Our tools are being used by Subaru factory techs, independent mechanics, and DIY hobbyists. We actually do testing and use feedback from professional Subaru mechanics before we begin selling a tool. All the feedback we receive is that they work as good or better than the OEM tools while also being much less expensive (as well as made in the USA and carrying a lifetime warranty).
We'd love to answer any questions about our tools so feel free to fire away!
Deej
Colorado
i use the ast subaru cam tool. the first one i had actually broke before i could get one of the cam bolts loose. i like it though.
Deej
Colorado
if i remember right though, you can get a big wrench on the camshaft itself. i cant remember what size wrench you need though. you might also have to jack up the motor to get to the bottom cam though
BK13
PDX, OR
Glad to see another factory rep on board. Welcome!
MiseryBay
SW Ohio
I have the AMS tools. They seem to work alright. If I had to buy again I would get the Company 23 set.
Company23
Not all of the EJ engines have flats on the cams. Most of the newer EJs have round cams. In our experience, it gets really sketchy using the flats because even if you can fit a wrench in the head, you run the risk of the wrench slipping off due to how awkward it is. It also is a hassle to remove the valve cover if you just want to renew the cam seals during a timing belt job. That being said, it can be done on some engines (like the phase 1 DOHC EJ25) with some swearing.
C
czgunner
WY
Company23, thanks for coming aboard!
Where are your tools manufactured?
dede2897234
Northern, Ohio
czgunner, you will find your answer about the tools' COO above.
Dave
c39er
Seattle, Washington
This is one of the needed tools for the DOHC subie that I used to use. I bought it from our local dealer. Close to $200.00 15 years ago!
It's a Kent Moore rtech tool, the real deal.
I have the other factory special tool for the passenger side that Subaru techs use too.
shockwave
Marietta,ga
I have also had luck with using a chain vise grip lightly by using an old belt that I cut to fit around sprocket to hold cam gear while the belt is of.
Or break nut loose while the belt is still on
If this can help u at all but a lot of times the sprockets are plastic and they will break while removing at times
rlitman
Long Island
On my SOHC, one of the sprockets was plastic. No way I'd put a chain on that.
I cut my old timing belt to be narrow enough to fit into a strap wrench, and used that to hold it. But I agree that if you're doing this a lot, a dedicated tool would be much better.
C
czgunner
WY
I can find the tools on Amazone, but the freight is $10 each.
Is there a vendor that carries C23 that will combine freight?
Nevermind, I found toolsource.com...
