Tire changer
rosadoauto
Need advice on tire changer for small garage 1500 dollar limit and will a tire machine work with 40 gallon 8cfm compressor
Sent from my SPH-L720 using Tapatalk
IndyGarage
Indy
small garage for personal use or professional use?
I have one of the Atlas rim clamp ones that Greg Smith sells. I didn't buy it from them, I bought it used.
It has worked fine for me for a couple years - probably about 100 tires across it in that time.
devoncoolman
quakertown pa
I just picked up a used snapon changer off my dealer for $1500. Buy used dont buy new. New machines will set u back more than $1500. Also buy a rim clamp machine. Check craigslist.
theoldwizard1
SE MI
Your compressor should be fine as long as it can make 100psi. Most changers have a "surge" tank built in so volume is not that big of a deal.
The older Coats machines are great, you can usually find them reasonably priced on CL (<$500) and you can rebuild them ! But unless you are EXTREMELY careful you can scratch the rims.
Chuck122
Québec, Canada
I would be careful with used machines, parts can be hard to get a hold of. I prefer machines with a thinner hand rather than the bulkier ones on newer machines. If you plan on using just occasionally on run-of-the-mill wheels I would not pay a premium for a machine with extra arms or rollers. With a second bar and some elbow grease you can usually get by.if you plan on doing more expensive wheels or low profile tires, I'd go for a machine with more bells and whistles.
I am not particularly fond of bar-less machines. At least the coats bar-less machine I tried left me very unimpressed
ccbrett
Hi guys new here we have in the shop a center post tir changer is that not recommended for 17in aluminum rims. In the past I've always used rim clamp type. Any thoughts would be helpful.
vpd66
Central Wisconsin
If it is for personal use and you are only doing a couple sets and some tire repairs a year. I would recommend the simple Harbor Freight $50.00 center post manual tire changer. Upgrade to a Nomar tire bar and you have a very handy tire changer. Once you get the hang of a manual changer they aren't that bad. I've had one for about 9 years now and i've got pretty handy with it. I've got less then $300 in the setup and it doesn't take up much room in my shop. Now I need to find a cheap tire balancer!
sberry
Brethren, Michigan
I want a real balancer, its on my short list. I just changed and mounted a new tire by hand on alum wheel with manual bead breaker and 2 screwdrivers, wasn't even worth the effort to walk it to the other building.
theoldwizard1
SE MI
The Northern Tool version is a bite nicer.
Manual Tire Changer Comparison - Harbor Freight 69686 vs. Northern Tool 13474
For those of you to lazy to lok up NoMar, here is a video showing their system. The mount/demount bar and proper lube are keys to the system.
Change a car tire on a No-Mar scratch proof tire changer
And in case you think manual changers can't do truck tires ...
No-Mar Tire Changer - How to change the tire on a Hummer
(I don't know why this guy refused to wait until all of the air was out of the tire before trying to break the bead ? :dunno: )
kevinnewcom1
Hello, I was able to get a Coats 20/20 tire changer for free that actually works. However, the 7 inch diameter cylinder is low on hydraulic fluid, how much does it hold and what is the best way to get it in that little hole.
