3157 socket tester?
Ign
Butte Peak ND
Is there anything on the market that would pop into a 3157 socket and then maybe have spade terminals so you could connect your own test lamp, alligator clips or DVOM?
I was dealing w a problematic socket yesterday & damn near had myself convinced the two bulbs I had available were bad, plus swapping bulbs back and forth got old. I didn't want to shove clips or test leads in the socket because it looks like a game of Operation: too easy to short.
I searched the web but didn't find anything.
Edit: I should say I really don't have the desire or TIME to make anything, just wondering if there's a ready-made product out there.
NHBandit
East Tennessee
I'm lost I guess. Being able to use a volt meter I can understand but a way to connect a test light ? Why not just a known good bulb ?
hayhauler71
MN
If you had your meter out and you thought you had a bad bulb why not test the bulb?
Rico.
England
If you're a DIYer like me, I bought myself a cheap version of the Power Probe.. It's
absoltely brilliant for quickly and easily testing automotive wiring... I works just like a test
light, with the added benefit of being able to supply power or a ground for testing
componants in situ.
My one was the equivalent of $30 and one of these combined with a multimeter is
everything a DIYer would ever need. Well worth it.
JimNut
North of Detroit
componants in situ.
More info on the off brand power probe please! I've been wanting one for a while now but can't justify the $$. Thanks!
Rico.
England
I don't know what your location is Jim, but I bought mine from an English tool company
called Sealey... It is actually an original Power Probe 1, just rebranded with the Sealey
name on it. If you're in the USA, I don't think Sealey have an outlet there.
What is the cost of an original Power Probe there..? Are they still even for sale..?
Surely they can't cost that much more than $30.
signcrafter
One side is ground and the other side has two positive terminals, one for low and one for high, right? Can't you just use your meter to see if you have ground and then see if you have power on the low and high terminals? A load pro would work good here.
JimNut
North of Detroit
I live about an hour north of Detroit in Michigan. I haven't really looked for the older original power probes. I just see the prices on the newer models and give up there. I'll look into the original models and see what I can find. Thank you for the info!
jkwilson
SW Indiana
Use heat shrink tubing on your probe tips and the meter probes can go in the socket easily without shorting to the shell.
Rico.
England
If the Power probe 1 is no longer available, I just had a quick look on ebay.com
and there are a few sellers that will sell the Sealey version including shipping to
the USA for about $28. Search for model Sealey PP1.
The only thing to bear in mind, if there is a problem or a fault with it, you will be
out of pocket one way or another, so if I were you I would do everything I could
to find one domestically.
Jbullfrog
Avoca, Iowa
I broke the glass on a bulb, cleaned the shards around the base, and use it to connect my leads. The legs supporting the filament are stiff and hold up well.
eyeballengineer
Sorry I just tried to Google what I had. There alligator clips with about one inch needle on the other end. I got them off the truck don't know who makes them.
shockwave
Marietta,ga
Just grab some test leads and hook directly to a 12v power source I use alligator clips on either end and hook it up directly to old battery usually has more than enough juice to power bulbs.
And what vehicles is this on I have replaced countless sockets on gm vehicles because the socket goes bad and not the bulbs
I
Ign
Butte Peak ND
Yep my '03 Burb had a socket w enough corrosion to cause issues, but this time it's an '02 Taco
skruft
There are also probes that have a plastic shield that either stays in place or slides up.
While I have much equipment, my usual way to test a socket is to first put in a new bulb and see how that performs, while at the same time examining the socket for physical damage or corrosion. I find that those are the usual problems.
bareass172
N'awlins
