Does gasket remover work?
neblinc
Lincoln, NE
Working on this Kubota Hydrostat transmission leak and the old gasket is really stuck on there. A razer blade is slow and tedious and is giving my fingers cramps ;)
Does that gasket remover they sell at O'reilly's help to soften it up?
Permatex or CRC is what I see they have.
Randy
RV77
Seattle
What I remember is it works in "steps".Takes a little off at a time.How about using a roloc disc ?
mdnelson86
Paxton, IL
The permatex stuff I've used has worked. It's still not an easy job, but it makes it a bit easier. You still have to work in steps. apply, let it sit, scrape off what you can. Then repeat the process.
N
neblinc
Lincoln, NE
Thanks guy's!
I am afraid to use any power type remover, don't want any junk getting inside this thing.
The part in the background is aluminum and I am always afraid to gouge the surface by being to agressive with the razer blade,
Will make a run to O'reilly's.
Randy
blacK20
I've used the CRC remover, and it does work. It needs time to soak in to be effective though. You literally need to apply the night before, and work it the next day.
Get yourself a good sharp 2" wood chisel and go at it at a low angle of attack (similar to the razor blades) much easier than a Single edge as you have a decent handle and can really bear down.
pepi
Woodstock, GA
Either of these will not remove metal, can be used with a hand drill, just use enough pressure to remove the gasket material. Using anything metal you have a chance of gouging the surface, scrapers or chisels not a good idea.
PEPI you pics died, and I've never had an issue using the wood chisel tin the 35+ years I've been using one. Get it too steep and start hacking, yes you can have an issue. Which is why I said "low angle of attack"
dowmace
KCMO
I use scotch brite pads on an angle grinder, if I'm worried about material getting inside the part I'll shove blue shop towels in any holes and pull it straight out when I'm done removing the gasket. Using a razor blade or any scraper always takes longer than for me to just grab the grinder and zip the gasket right off.
Craptain
Tampa Bay FL
I used to use a chisel like Outlaw said. Until I got a die grinder with Roloc discs. Still have to be (very) careful but it sure is quicker.
KSJeff
Andover, Kansas
Me too. Grind and then wipe with brake parts cleaner and paper towels until clean. Hundreds of motors. No problem.
Fretters
South Yorkshire, England
Try scraping with the edge of a copper coin, (or suitable block of copper), rather than a razor blade. You have no fear of digging in with the copper, no matter how hard you press, and it is surprisingly effective.
Honda guy
North Carolina
By far the best gasket remover I've used, is Wurth gasket/paint remover.
I've tried the Permatex stuff and wasn't impressed.
clueless
small northeastern pa town.
done them transmissions quite a few times, use a razor scraper to get the heavy stuff off then scotch brite cookie on a pad grinder, flush it with brake-clean or either/starting fluid. works every time.
cmanningjr
I've used permatex gasket remover and it worked great..Just follow the directions..
N
neblinc
Lincoln, NE
I let the permatex soak overnite and most of it came off pretty easy. A 2nd application should take care of it.
Thanks everyone for the tips.
Randy
RCStocker
Indiana, California, Australia
I use razor blade holders. Years ago they were very common and I have a bunch of them that are just bent rod welded to a holder.
Some things just take a long time. I have gasket scrapers but find that I go to my junk wood chisels for 90% of my gasket removal.
I would not us power anything on an aluminum block or part.
I don't think you will do any damage with a sharp chisel.
I have rebuilt tractors, buggies, boats and cars and never had a problem using a chisel.
Just take your time. Not all products work on every type of material. You might need to experiment.
Big Pete
I use a piece of copper pipe hammered flat and sharpened with a file, it's harder than gasket material, but softer than most ally castings, and it holds a better edge than hardwood.
