King canada
sasky
Any have any experience with quality of there stuff? Worth buying or stay away?
ADSR
All of their products are rebranded. It's hit and miss with them. What were you looking for?
aptdweller
Ottawa, ON
I have a few things from them that work well, but on the whole they aren't a quality product. I'd look elsewhere when buying new. Is there something specific you were considering?
01ps
I have a compound sliding mitre saw. Works ok, but wish I had spent a bit more and got a better one. Not the best quality, but like I say, cheaper, and works ok.
The Cobbler
I have an oscillating tool by King. it's OK but not any where close to Fein ...
it serves my purposes alright but if I was using it everyday probably would have a different opinion.
sasquatch12
Have the 10 inch sliding miter saw, noisy gears but works fine. Also have the 4 1/2 inch disc grinder for 10 years tough little grinder still works great.
Also have the milling machine , the one with the bigger table, 1hp, works real nice.
sasky
Well looking at a gear head drilling/mill and the 3 inch metal belt grinder. I never bought any of there stuff but kinda had the hit and miss feeling bout junk
ADSR
It's rebranded. And I believe grizzly sells the same one. Try there and lookmfor reviews.
sasquatch12
Sasky, the King model mill/drill i bought is comparable to the Grizzly G0704, but mine has the longer wider table that has more X and Y travel.
When i got it , i found it needed barely no tweaking at all, just the general cleanup, i also bought the factory stand with it.
If you google "Hoss Machine" it has a bunch of info and reviews there about the Grizzly model.
trainer
Northern Ontario, Canada
I have a 12" thickness planer. I bought it because I had 500 board ft of red oak to plane .
It needed a bit of tweeking out of the box, but it's been reliable. and accurate. I can get replacement blades locally.
Also Have a biscuit joiner that I bought used at an auction. Not fancy, but it works well.
Sureshot
Bridge Creek, OK
I have one and may be selling it in the next couple months due to a move. Let me know your timeframe.
I have a 10" bench grinder that has seen heavy commercial use and only the power switch failed which we replaced. The failure was due to employee abuse.
I have the sander as well but it has not seen a lot of use. I believe the scroll saw is from them as well.
