Who makes the best drill bits for drilling steel?
kenburkholz
Usually, any good brand of U.S.A. made drill bits will be o.k., but don't forget there are several good imported offerings. If you want your drill bits to last, you need to use them correctly. When drilling steel, you need to lower your speed so the bit can do its work. You also need to lubricate the bit so it won't overheat. There are many products out there for drill lubrication, but you can use just about anything like motor oil. the thing you want to do is flood the drill, not just to lube it, the main purpose of the oil is to remove heat during the drilling process. If used incorrectly, you can ruin a high quality bit in one use. I have imported bits I have used for many years. A good place to see what is available, Is Mc Master Carr. com they carry a very complete selection of all types, and are great to work with. Ken.
sasquatch12
If you aren't in 100% right now, watch garage sales for USA made bits. Usually they go pretty cheap.
My favourite is "Butterfield", but i'm hearing lots of good reports about "Triumph" drills made i think in Wisconsin.
techenthusiast
What is everyone's opinion on the snapon thunderbit? They come from triumph and they are bronze and black oxide HSS. I know they are overpriced but without cost what is your opinion
oldtractors
Iowa
I like the Triumph Thunderbits. The ones I have are mechanic length and have flats on the shanks for drill chucks. You can get them at Enco for a pretty good deal.
silentpoet
I have a small Milwaukee drill bit set that I got at home depot. Has worked good on 3/16ish steel when I have used it. I have not used it enough to tell you how long it lasts though. But it works pretty well in my drill press.
FriendOfYours
Any brand in Cobalt. Oiled properly and you can get a gazillion cuts out of them before they need sharpening
papasmirf
Find and use only cobalt bits and drill at 500-600 rpms max. And buy a drill doctor. Mine works well.
Farmall450
Marengo, Illinois
Hansen, most US made ones. I believe Vermont American and Montana bits are both excellent, available at Menards and probably Farm & Fleet, and US made.
A_Pmech
IL
The brand of the drill isn't nearly as important as the operator using it.
Pricing is much better if you buy drills by the pack.
zkling
:+1: As long as it is straight and of reasonable quality you can get it to cut good. What type of drilling are you doing? Size? Machine? Any coolant? Do you know how to sharpen bits? This can really save you some $.
ishiboo
Oshkosh, WI
Vermont American (Bosch) bits are not made in the US, are they?
I bought a set of the Montana (made in Montana!) hex shank bits and they're well made and strong. Don't look fancy but they work well!
czgunner
WY
This is something that MAC tools does well. My HSS Mac bits have a lifetime warranty.
My driver has replaced several broken bits for me.
They are okay, not in the same class as Norseman, but for work they're great. I don't worry if they break.
MattPersman
Indiana
The Mac ones are lifetime warranty +1. I told the driver you offer me a lifetime drill bit I will buy it every time. They are average on quality.
sberry
Brethren, Michigan
It is a combination of education and experience. AP has it right, I got a pail full and don't know one brand for another, and I drill about 99.5 steel dry and by hand. Big holes are fewer and its too slow to fit everything to do machine drilling, I am done before someone has it clamped or its on a machine.
Battery drill is the ultimate thing they ever invented for drilling steel. I get a few small bits at the flea mkt from a vendor that gets them direct, cheap as imports but they are super good.
I am a maniac hole puncher and at a dollar I don't usually sharpen real small bits, they are stressed and worn I toss and next year score another dozen for punching pilot and on occasion he has grab bags of assorted for real cheap. I am scoring a sack next year, from about 5/16 to 7/16, 15 for 14$,,, ha, disposable.
Some of my bigger ones are more careful with and I need to do some sorting. Buy a couple of each in practical sizes, 1/4 and 17/64 and a dozen between 1/8 and 3/16 for pilots.
I pay a $ for small bits and bought a bag of 10 1/8 and 9/64 for a bit less, still got half of each. Its a rare day I don't drill a hole in steel. Very little production but one off installation and light fabrication.
Jay W
Yakima, WA
Way to general.
A 1/16" cobalt in mild steel will run about 3900 rpm.
A 1" in mild steel will run about 240 rpm.
Gregg33
Port Colborne, ON, Canada
Norseman are my preference. If you are limited to big box stores, the offshore DeWalts are good too. As others indicated, it is critical not to overheat the bit regardless of brand. Oil, the proper speed and even stopping briefly to let the bit cool will help your bits stay sharp longer.
