gregtwojeeps
At work we have a gym where a LOT of towels are used that the owner maintains. The architect/builder put the washer /dryer in the one car garage out of the way and there is NO physical space to move the W/D elsewhere, or I would have done so already. ...
The mechanical contractor that installed the 4 in. round metal vent for the dryer had to run it up the wall about 9 ft. and then across the steel ceiling bar joists. He exited the vent duct out through the 8 in. cinder block and brick, right above the 10 ft. tall garage door to daylight...
The duct run total length is around 27 ft. with 3- 90 deg. ells being used, so knowing the dryer would not vent properly, the contractor installed the in line booster fan I linked below. ....
I have replaced 3 of these fans thus far in 5 years as I suppose they burn out when the inpeller gets full of lint and makes it drag. Plus the long vent line is making the attendant use too long of drying cycles to compensate. ..
What would a solution be rather than just keep buying these $200.00 fans ? Do they make a larger in line 4 inch exhaust fan (120 Volt) that could handle the lint and get more exhaust ? ...
Or, maybe a pre-fan lint collector paired with a larger ex. fan ? How does one know if they get too much CFM exhaust for the dryer (residential grade) to be able to dry properly ?
I can't believe an architect designed the laundry room this way.
Thanks, Greg
http://www.grainger.com/product/FANTECH-Inline-Centrifugal-Duct-Fan-5C516?searchQuery=5c516
Thanks, Greg
to all that helped out here ! ,
