SUNBURNTsnype
- Joined
- Nov 25, 2012
- Messages
- 41
Hey guys,
In my line of work, I frequently encounter the snapped off, broken off, russted or corroded fastener that I need to remove with as little collateral damage to the existing thread hole as possible. Often times, this involves drilling out and extracting, or completely drilling out and re-tapping, or over boring and installing a helicoil or thread insert, or sometimes even completely plugging, and drilling a brand new hole and drilling and tapping a new hole.
Anywas, on several occasions, the extractors we are using to remove the fasteners end up breaking or snapping off and become lodged deep in the hole I just drilled, and then I spend the next several hours and several drill bits trying to drill out the hardened steel or tungsten material of the broken off extractor, and sometimes further damage the threaded hole in the process.
Obviously, we try to prevent as much of all of this as possible, from heating the fasteners and using penetrating oil, to shocking them with hammers and punches, etc. etc. but sometimes, after years and years of salt water, corrosion, electrolysis, heat cycling, etc. there is just no easy way to prevent these situations (I work on ships built in the 60's and 70's FYI). So I was just looking to pick your guys' brains for any tips and tricks and special tools for when you old timers have run into these type 'oh sh*t' moments when something breaks or snaps off and now you spend 2 days trying to extract a bolt from an irreplaceable piece of machinery without damaging it. We have a magnetic base drill press and I frequently have to make steel bases or flanges that can be affixed to whatever i am drilling in order to stay perpendicular to the workpiece. SOmetimes its not feasible however. I have tried diamond drill bits, carbide drill bits, high speed steel bits, cobalt bits, endmill plunge bits, carbide burrs, etc.
What is the best type of bit and material for drilling through a tungsten extractor when it gets broken off inside of a stud or bolt?
What are the best extractors that wont snap and shear off when i put a little torque on them? WHat is the best penetrating oil to get into tight joints?
I am in the process of procuring a Mini-ductor for our shop, which should definitely help. Are there any other specialized tools I should look at?
Are there any chemicals or mixes for dissolving certain metals when dealing with 2 different types of metal such as a steel stud and brass or aluminum housing, etc?
Thank you in advance for any help and advice.
