Craftsman Torque Wrench Ratchet repair Kit
e9sgtmajor
I have a Craftsman 1/2" drive 150 ft lbs torque wrench, Mdl#4970897035. The torque part of the wrench is accurate, what does not work is the ratchet head. Can anyone tell me who makes these wrenches for Craftsman, or where I can possibly purchase a ratchet repair kit for this model wrench. Thanks, in advance, for your help.
Uncle Buck
Kansas
I took an old Craftsman clicker in and they rebuilt her and had me out the door pronto some years ago.
bennyy
San Francisco
I have a cman torque wrench also broken few yrs ago, can i still bring it back and get it fix? on the box it said one yr warranty.
billymade
New Mexico
Sounds like it is out of warranty; they do sell parts and the heads are rebuildable! Major repairs are typically not cost effective and when you factor in the cost of recalibration/repair; it is typically around, if not more then cost of a new one.
eschoendorff
So is pronto just a term old duffers use anymore? :lol_hitti
Last I checked it was still part of the vernacular. Not sure what the confusion is...
The ratchet head on that TQ wrench should be warranty-able... you should be able to get a repair kit at Sears if you talk to the right person.
nissan_crawler
Wichita, KS
It's not under warranty but the kit is only $11-13 if I remember right.
Here's the guts:
Uncle Buck
Kansas
Here's the guts:
Man Nissan, you must have some real A holes at Sears in Wichita! The Topeka store will rebuild a torque wrench with ratchet guts and not blink an eye. That is all they will do for the torque wrench though.
E
e9sgtmajor
Thanks for the pictures of the ratchet assy. Very helpful Got the part I needed from Danaher Co. I guess Sears does not have a standard poiicy on torque wrench ratchet repair. Some stores will repair the ratchet assy, others won't
vssjim
McLean Va.
They only will rebuild the ratchet free or give you a kit, that is the policy but the store must have a rebuild program for ratchets to have kits. If they try to sell you the kit they a either one penny or nintey nine cents it seems to change year to year.
Junkman
Northeastern CT
Pronto???:headscrat
Pronto is a distant cousin of Tonto, of Lone Ranger fame. :lol_hitti
My Craftsman click type torque wrench says it has a lifetime warranty, and I still have the paper work that came with it in 1965. I told the store that it was out of calibration, and they offered to replace it with a beam type wrench. I said that I want the identical or type, and was told no. I walked out of the store and never bought another Craftsman tool, except used.
billymade
New Mexico
Again, you probably talk to a manager and you could get a store credit through a sears gift card to get something else or you could contact Sears customer relations hotline and see what they can do for you. The main issue is; anything they give you (aside from a beam torque wrench) will not have lifetime warranty. You could ship your wrench off to a place like www.teamtorque.com and they could calibrate it for you. I would take the store credit if you can get it and buy a professional torque wrench off of sears.com (they offer OTC, Precsion Instruments, KD, SK, and more): http://www.sears.com/shc/s/search_1...rench&gobutton.x=0&gobutton.y=0&gobutton=find
You might contact Sears and see if they can do anything for you:
Customer Relations Hotline:
1-800-549-4505
Email us your questions, comments and experiences
or send a letter to: http://www.sears.com/shc/s/nb_10153_12608_NB_CSeMail?refLink=relations&adCell=A4
Sears National Customer Relations
3333 Beverly Road
Hoffman Estates, IL 60179
Just keep in mind; at this point, I do not know of anyone in the marketplace that offers a lifetime warranty on their torque wrenches; much less the calibration, seems if you are a pro, you should have it calibrated yearly or more depending on how much you use it.
Here are some tips from teamtorque that might be of interest:
http://www.teamtorque.com/tips.html
Caring for your Torque Instruments
• Calibration: Most torque instruments have a factory calibration recommended interval of one year. Many torque instruments may need to be tested multiple times per year depending upon the usage and user needs.
• Storage: All torque instruments should be stored in their original case. Avoid any storage locations that are subject to high or low temperatures and high humidity. "Clicker" style torque wrenches should always be turned down and stored at the torque wrenches lowest possible setting.
• Usage: Before and after every use, make a visual inspection. Look for any signs for wear or deterioration. Make sure the unit is locked on the proper torque setting before use. Grip handle correctly in the proper position and secure your feet for possible breakage of tool. We recommend safety glasses when using any torque wrench or torque product.
Reasons for Failure
• Use - Highly used instruments will show more wear than those that are only used occasionally.
• Abuse - Using torque instruments for jobs that they were not intended. Do not drop your torque wrench or overload the wrench with a pipe extension.
• Improper Storage - Storing the tool in conditions that will lead to the corrosion in the tool. High humidity areas for instance. Storing "clicker" style torque wrenches in any setting besides the lowest one will cause main spring wear and failure.
• Improper maintenance - Failure to properly have the tool cleaned and calibrated on a yearly basis. Checking the instrument before and after every use. Failure to send in for replace worn or broken parts.
