shopboy13
NY
Put together the base for my mobile chop saw station.
I've got one I threw together outta 2x4's but I think I'm gonna do something like that. Smaller foot print and ahold more dust on it. Thanks for the picture.
northwestpat79
Picked up a propane forced air heater on Craigslist... so I can warm up my garage... so I can finish painting the walls... so I can properly place some big cabinets against the wall... so I can clear floor space... so I'll have room for the Bend Pak XPR-10A I'm going to order next week. :D
BellyUpFish
Alabama
Put together the wife's punching bag stand..
Mounted a 30' cord reel..
Installed the new 20T bottle jack into my press..
Gathered some bits for my electrolysis rust removal tank.
littlebritishcar
Napa. CA
I started to assemble the gas pump that my Mom's husband gave me for my birthday. I was going to restore it but I kind of like the patina for now.
I also picked up the TH350 transmission I had rebuilt for my truck. I hope it works as well as it looks because she sure is purdy. :drool:
BlueBomber
Outside Boston, MA
Yesterday: painted the walls, placed the butcherblock workbench, bolted a Gladiator cabinet to the wall, brought in the second workbench from the shed, installed it, built new top for the 2nd bench from spare 2x12s and plywood left over from barn renovation, assembled second Gladiator cabinet, unpacked tuned and ops checked the cheap HF bandsaw, and generally cleaned, swept and moved piles around as I continue to get the garage back up and running.
Scud67
Metrowest Boston MA
Finished setting up the computer for the shop, cut down a hollow door, installed the wood fillers to the top and bottom of said door, painted the door (to be installed inside the house later this week), updated the software on shop computer and started looking at "Alldata" type software and some type of vehicle maintenance software....found the cam seal leaking on my wife's car - will be repairing that later this week as well.
Stroked383
St. Louis MO
Modified the helper bag brackets to try to gain as much clearance. Between modifying the bottom perch and raising the top bracket up all the way it worked perfect with now 5 inch lower rear.
Stroked383
St. Louis MO
O and also sorted some nuts and bolts that I got for free. My nut and bolt selection in the garage *****. Lowes is right up the street so we usually take the scooters up to get hardware as needed. Friends father passed and he had buckets of new nuts bolts and washers that he gave me. Sweet now they need to be sorted.. :eyecrazy:
Junkman
Northeastern CT
Took the air conditioner compressor off my 1962 Chevy, and found that the leak was not the compressor, but a hose that had come loose. Next is to reseal the entire unit, and install new barrier hoses, re charge, and enjoy the cold air in the heat of the summer.
41ratrod
Springfield Mo.
moved the 41 ford out of the shop and when to move the 57 Hillman out but the battery was dead bought it new in Dec. and started last weekend.
I checked it with the meter and O volts and charger wouldn't charge it, back to w-mart Monday.
Worked on the bench top English wheel I'm building.
Also did some cleaning up.
Peanuts and M/Ms in the shop keep me going.
R-132 Fan
Central Texas, East of Austin
Took advantage of the nice weather to solve a brake problem on my John Deere 210 garden tractor. The brakes had been hanging up and not releasing since I replaced the brake band. I found a rusted shaft that was seizing up in the bushings it passes through and some grease fittings that hadn't seen grease since the machine had been assembled in 1976.
It's a great day when I can repair something with wire brushing and some grease and not needing any new parts!
9GUY9
Mankato, MN
Powder coated a couple bike frames, and finally remembered to weigh them before and after. I've had a few people asking me how much weight powder adds.
https://scontent-b-iad.**.fbcdn.net/hphotos-ash3/t1/1939569_270749086427176_101022590_n.jpg
https://scontent-a-iad.**.fbcdn.net/hphotos-prn1/t1/1240036_270749113093840_1620484390_n.jpg
https://scontent-a-iad.**.fbcdn.net/hphotos-frc3/l/t1/10013949_270749123093839_1472080018_n.jpg
https://scontent-a-iad.**.fbcdn.net/hphotos-frc1/t1.0-9/1959478_270749133093838_869518964_n.jpg
The answer, about 18-40 grams per coat.
Lippyp
Shropshire, UK
Disassembled my £20 ebay garden roller, knocked the shafts on each end straight, broke out the mig and welded up the crack that ran around one end which leaked water, wire wheeld the old flaky powder coat off the roller, gave it a coat of Hydrate 80 rust converter, cleaned the bronze bearings on the frame, removed the grease ******* and cleaned them through. Just waiting on the rust converter to dry and I can put some seam sealer on the welds to seal any pinholes and then paint.
At the weekend it was all outside stuff, went over to pick the roller up from my sisters, came back via the garden centre with a load of plants, compost etc. Sunday was spent fixing the flower bed surrounds I built and planting a bunch of climbing roses which is why I look like I've been fighting off a lion. We had an unseasonably warm day and even had lunch outside in our orchard. It actually hit 20C in parts of the UK which after the wettest winter on record is a bit of a relief. Looks set fair this week at least.
aka Larry
Eastern, NC
I worked on a handicap ramp for my miniature Dachshund 'Katie' who had back surgery a few months ago. Pics to follow when I finally get it done.
48RON54
Inland Empire, CA
Nothing much to report got done in the garage this weekend.... I had intended for great things happening out there but yardwork got the best of me yet again..... Apparently wife would like some stumps pulled too <sigh>
sixleaker
Chico, CA
Got some work done in the camaro. Mocked up the upper and lower control arms, got the new spindles and brakes mocked up also. Almost ready to the appointment a the chassis on Thursday for a cage
Scott H in Wheaton
Plainfield, suburb of Indianapolis
Rolled my 65 Mustang out of the garage, swept out a bit and got ready to work on the car.
Installed intake manifold, spark plugs, radiator, carburetor and misc brackets and trinkets.
Still have to get underneath and hook up the headers to the existing dual exhaust, then I can fire the engine and break in the cam.
As it looks today
Engine BEFORE cleaning and re-working
Cleaned Cobra intake
